Question about HP Compaq Presario F762NR Notebook
Ok I had to buy a new hard drive for my Compaq Presario F762NR laptop the other died! the new hard drive works great! ty WD! now my problem is that I don't have the driver to the built in webcam and it isn't found anywhere!
  • 194 Answers
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
My Compaq presario cq70-120us wont work =P it needs a new hard-drive, and currently is without one, when i plug it in and hit the power button, it turns white, but the screen remains black without any...
i would expect to see the compaq logo come up, and you should be able to "post" (ie bring up the bios or a diagnostic screen) even if there is no functioning hard drive.
at least I would expect it to pop up with something like operating system not found,
you might be better off replacing this one (sorry)
Oct 17, 2010 | HP Compaq Presario CQ50-110US Laptop
Can I increase disk space for Presario F762NR notebook? And if so..how. Thank-you
You can compress the disk and gain a little room which might meet your needs, otherwise you can buy a new disk and install it. I have cloned many laptop disk drives onto new ones. It does take some special cables and and a desktop computer to do however.
Before I do either, I'd try a disk clean up. Turn system restore off then back on to delete all the SR files. Down load CCleaner and run it against the disk and run the registry cleaner.
http://www.piriform.com/ccleaner/download
Disable Hibernation and delete Hiberfil.sys, if the space problem is critical on your System Drive. Its a hidden file on the root directory of your system drive. Open Control Panel. Type Hibernate in the search bar. Select turn Hibernate On / Off.
If you want to try the compress, double click My Computer, right click on the C:\drive, PROPERTIES, check Compress this drive.. This will take awhile so don't turn off the computer or let it shut down. Some say you should not compress the windows folder but I've never had a problem and they slow down is almost not noticable.
Aug 04, 2010 | HP Compaq Presario F762NR Notebook
Webcam Driver Missing Presario F762NR
log in to the www.hp.com and select the support and Drivers and select download drivers and S/ws and type the Product No and enter go
select operating system and then select the webcam driver download it to the NB and run it to install
Feb 02, 2010 | HP Compaq Presario F762NR Notebook
My display on my compaq laptop f762nr randomly goes blank while the programs are still running. The only way to get it back is to hold the power button for about 5 seconds to turn it off and then turn it...
sounds like you need to change your power settings
go to
start
control panel
power options
then you can set all of the options for standby ect set them all to never and see if the problem continues
Nov 24, 2009 | HP Compaq Presario F762NR Notebook
Harddisk is not getting detected
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your
Apr 28, 2009 | HP Compaq Presario CQ60Z Notebook
COMPAQ PRESARIO V2000 BOOT PROBLEM
As much as I would like to tell people do not buy seagate I can't, Most Seagates are having problems, depending on the serial number you might need the firm ware up date. Secret WD is the way to go, better warranty, last longer to.
Feb 21, 2009 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
HP Compaq Presario F762NR Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
