Question about Nokia 2115i
Nokia2115i cdma keypad button 2 not working - Nokia 2115i
  • 179 Answers
Open your phone cashing up, than open white plastick behind keypad.search the button with the problem then clean up the botton and PCB with pencils eraser,make sure it clean,so the connection between dom keypad and PCB well. turn back as before.I hope it help.
Posted on May 26, 2010
The top quick access buttons stopped working 2 days ago. The bottom buttons still work but, we can't punch in a custom time. The only thing that will work is the 1 for 1 minute 2 for 2 minute...etc.
One of two things is happening, either you have broken connections in the membrane switches of the keypad and should replace the keypad(which is most likely) or your main control board has failed in a way that it can no longer read signals sent by the keypad.
Aug 04, 2013 | Microwave Ovens
Goldline controls troubleshooting
Drained/dead battery
Plug your iPhone into your computer or wall adapter to charge. If it does not charge when connected to either of these, you probably have a dead battery. The battery will need to be replaced (GSM (AT&T) or CDMA (Verizon)).
Bad display
It is possible that it appears nothing is happening because the display is bad. If the iPhone sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced (GSM (AT&T) or CDMA (Verizon)). Unfortunately, the LCD and glass panel are fused together, and must be replaced as one unit.
Bad logic board
If nothing else works, your logic board is probably bad and needs to be replaced (GSM (AT&T) or CDMA (Verizon)).
God bless you
May 24, 2013 | Cell Phones
How do you turn on bluetooth on kyocera qualcomm 3g cdma phone?
    • 1 Turn on your Kyocera Qualcomm pdQ by pressing and holding the "Power" button until the welcome screen is displayed. If the keypad is open, press and hold the "Power" icon located on the right hand side of the phone's screen. Repeat the process to turn the phone off.
    • 2 Install the Palm Desktop Organizer software. Connect your phone's cradle to your computer and plug in the power cord. Remove your Kyocera Qualcomm pdQ from its cradle during installation. Exit any Windows programs on your computer. Put the Palm Desktop CD into your computer's CD-ROM drive. The installation screen will appear, click the "Install" button and follow the on-screen instructions.
    • 3 Perform your first information HotSync. Click the "Palm Desktop" icon on your computer's desktop. Click the "Sharing" button in the Windows taskbar to open the HotSync Manager, then click "Local." Turn on your phone and put it in its cradle. Open the Kyocera Qualcomm keypad, tap the "Sharing" button to open the HotSync menu and select "Local Sync." Enter your username on the computer and click "OK." When the sync is complete, a "Process Complete" message will display.
    • 4 Make a call with the keypad closed. Pull up the antenna on your Kyocera Qualcomm pdQ and wait for the signal strength icon to be displayed. Use the numeric keypad to enter the phone number. Press the "Send" button to make the call and the "End" button to hang up.
    • 5 Make a call from the call history on your Kyocera Qualcomm pdQ. Press the right "Smart Key" and use the "Up" and "Down" button to scroll through your call history until the desired number is highlighted. To see more information about the number, press the left "Smart Key." Press the "Send" button to make the call and the "End" button to hang up.
Feb 24, 2012 | Kyocera Cell Phones
My precor efx 546 keypad comes on, the enter button accepts all the info and programs are displayed. 1. The quickstart button does not work. 2. Both crossramp and resistance do not move either when...
1. Sounds like you need a new keypad if some buttons do not work. 2. If those buttons do not work either, it sounds like you need a new keypad, possibly the upper board. Make sure the keypad is plugged into the upper board and the connection is not corroded. 3. Older 546s used an electromagnet to produce resistance, newer 546s use a generator and resistor to produce resistance. I have never seen a 546 that used a motor that moves back and forth to produce resistance. Some residential crosstrainers use a motor like you describe.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
I have somehow locked the keypad on my LG Banter it is a prepaid phone as such i have no account number or I do not receive a bill and I have no idea how to recover this 4 digit code to unlock...
Here is your solution:
1. Download CDMA Phone Tools
Here: "http://isohunt.com/torrent_details/110130265/cdma+workshop?tab=summary"
2. Install and launch the program. When I did, it set my antivirus off but after some reasearch it appeared to be okay. After I used it, it didn't damage my system so I don't think it was a virus. However, use at your own risk.
3. Plug your phone into your computer and let windows find the drivers. If for some reason windows doesnt find the drivers you can get them
here: "http://www.lgmobilephones.com/softwaredownload.aspx"
4. Once the phone has installed in windows run CDMA Workshop. I had to click "run as administrator" or it wouldent launch, I'm running windows Vista 32 bit.
5. Once CDMA Workshop has launched set all baud rates to 38400 in the Com settings, AT mode and DM mode should both be set to 38400.
6. One at a time starting with COM1 try each COM port and hit "connect". If it is successful it will tell you at the botton it has connected to the COM port. If there is nothing there it will tell you it failed. If it fails try the next one till it says connected.
7. Once you have connected click the "Read" button. If it tells you "Failed.. Phone Does Not Answer" you have the wrong COM port. Click "Disconnect" select the next COM port number and repeat until you see a bunch of info pop up on the left.
8. I was not able to pull the unlock code by clicking "Read", I had to use the one of the 3 buttons under the "DM Mode" Section. The button "LGDM" worked for me, I honestly don't know what the other 2 do.
9. Look to your left and WALA! you should have an unlock code displayed.
10. Thank me, because my fingers bloody hurt now. lol
Hope this helps you out and everyone who is stuck on this, it took me hours of reading and compiling info to figure this out.
Take Care
Jeremy
Dec 01, 2010 | Cell Phones
The down button the numbers 2, 3 and end call button have stopped working. when i press one of these buttons its shutting the phone down-any ideas or advice please?
Hi, it's the keypad IC or the keypad itself. So you can check the keypad if there is dirts that is stopping the keypad from working. Or the keypad needs to be replaced.
After checking the keypad if the keypad still did not solve the problem,
You will have to replace the keypad IC inside the board of the phone.
Take care. .
Aug 20, 2010 | Sony Ericsson K850i Mobile Phone
I want 2 use LG rd3500 CDMA handset as a general CDMA phone for any CDMA network.How can I do it? Currently I use Reliance CDMA on this phone but I want 2 use another CDMA (Tata Indicom) on this phone.
You can't. CDMA works on on a different frequency (band width). GSM (AU) networks operate at 900Mhz,1800Mhz or 2100Mhz as 3G. Sorry about the bad news
Jul 03, 2009 | Lands Phones
KEYPAD NOT WORKING ONLY POWER
KEYPAD NOT WORKING ONLY POWER. ALL BUTTON ARE NOT WORKING FOR NOKIA 2600C-2.
Feb 04, 2009 | Micro Application Dreamfall: The Longest...
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Unlock cdma verizon for to work with telus
Did you try the six Zeros? if you could post or email me the ESN Hex. i might be able to get the SPC code for it. so you could follow telus instruction on programming the phone with them.
Verizon phones could be unlocked via keypad codes. code generators, and via software. Also please post the phone brand and model.
Thanks
Dec 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 2115i Logo
65 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
