Question about Uniden DECT 6.0 Cordless Phone ID
What is wrong when the phone says Check tel line?
  • Uniden Master
  • 8,016 Answers
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Posted on Feb 03, 2010
  • k24674 Mar 02, 2010
    My answer was taken from a Uniden phone manual. You should consult the specific manual for your model. Dect6 refers to a plethora (multitude) of models.
I got that too! CenturyLink came to a Telephone line and setting up our Prism and our phone. Check to see if a cable truck is over your phone line and try again later.
Posted on Jul 19, 2012
5 Suggested Answers
  • 1417 Answers
SOURCE: message displays "check tel line". All
What you need to do first of all , put of the phone then disconnect it from the power supply allow he phone for about five minute ,then put it on again check the phone respond on your command if the problem remain same or solve.
Note if the problem remain then you will need to send me the name and the mode /serial number of the phone to guide you further.
Thanks.
Posted on Sep 06, 2011
  • 51 Answers
SOURCE: my phone says check tel line.
I have a similar model from the same manufacturer.
You've got the AC adapter plugged into the wall and the phone base, and the phone wire with std. phone connectors plugged into your phone jack and phone base, and it's still not working.
This can happen if the phone line is not active, or if the "pair" of wires is reversed (which is how DSL worked exclusively for years). Ultimately, it's not sensing a dial tone on the line you're base is plugged into.
First, make sure you can hook up a std. phone handset, if you have one, to the active phone line wire and plug to make sure the line and wire can result in a dial tone. Then, unplug that phone and plug in your new base. You should now be able to use the phone.
If, for any reason, you can't get a dial tone, it may be possible the plug you're using had a two-line phone plugged into it previously, which places the other line on another pair within the 4 wires for that type of plug. In other words, the active wires you want are in the wrong place for the phone to access.
I would recommend taking this handset to a phone jack you know to work fine with a single-line phone, near an AC outlet, and give it a try there like I outlined above. If it works there, then it's just the phone jack and maybe wiring position that is your issue.
You can also find at many hardware and electronic stores a simple phone line checker. It's a small box with some lights on it, with a short phone cable and plug coming out of the other end. You plug this into your phone line jack, and it tells you if the phone wires are wired correctly (typically a green light), or crossed (red light). This may be the source of your problem.
I hope this helps!
Posted on Feb 16, 2012
SOURCE: Phones stop working
What system is this on?
Posted on Aug 04, 2009
SOURCE: "check tel line" message?
have you paid you bill? Seriously ring your provider and get them to check your line out.
Posted on Feb 12, 2010
In normal condition phone continuously ringing what do
There could have been a short or ground in the telephone line (Tip and Ring). Please check the connection of the Tel line cord in the junction box. If your Tel line consist of 3 wires, disconnect all three wires, lift the handset, connect only 2 wires going to Exch Line or Trunk line (Local Tel Company) until you hear the dial tone. Leave the other wire disconnected.
This helped me isolate the problem, I hope this applies to you.
Best regards.
Sep 02, 2015 | Lands Phones
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
"Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
Feb 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
I can send faxes but can not get a fax. It rings and does not pick up. I have it set for two rings. Hp 6128. I called the phone company and they said if it can send faxes there is nothing wrong with the...
CHECK THE BCK OF YOUR FAX WHERE THE PHONELINE PLUGS
IN THERESHOULD BE 2 LINE JACKS 1 SAYS LINE THE OTHER SAYS TEL KEEP IT PLUGGED INTO LINE JACK. IF YOU NEED
TO SWITCH IT TURN OFFFAX WHILE DOING SO RECONNECT
THEN TURN BACK ON.IF THIS DOES NOT WORK 99% CHANCE
YOUR MODEM PWB IS DAMAGED
May 13, 2010 | Office Equipment & Supplies
Feb 12, 2010 | Lands Phones
Phones stop working
Aug 04, 2009 | Panasonic Lands Phones
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
HELP....
check the power or battery of this phone. and make sure the tel jack is wire up for 2 line phone,if you using 2 dial tone from carrier.
Sep 20, 2007 | RCA 25202RE3 Corded Phone
Uniden DECT 6.0 Cordless Phone ID Logo
4,945 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
