Canon IR 3100 error code (E000020-0081)
I have a canon image runner 3100 color copier, fax, printer. I do not have a service manual to check this error code. It also gives a replace cyan toner. the drum and all toners have been replaced but still getting this error code.
Help!!!!!
Barry
  • 2 more comments
  • glick66 Mar 31, 2008
    I have got the same problem : error code E000020-0081.
    I have repalced the 4 developers and the drum. I have cleaned the Patch read image sensor and the ATR sensor.
    Error code is till there.
    What can I do ?
  • teotess Dec 17, 2008
    I have same problem with iR3100C, error code E000020-0081, Help!
  • basher_73 Apr 18, 2009
    I have a canon image runner 3100 color copier, fax, printer. I do not have a service manual to check this error code. It also gives a replace cyan toner. the drum and all toners have been replaced but still getting this error code. error 0070-0001
  • Nitin Gupta
    Nitin Gupta Jan 15, 2014
    i have problem Eror code is E000067-0110 help me ........plzz tell me solution
Error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Posted on May 20, 2009
  • neer_sarswat Aug 23, 2011
    cleen the durm sanser
  • sunday mbwambo May 02, 2013
    my photocopier machine ir 3100CN apear Erro no E000020-0081
E000067-0100
Posted on Dec 23, 2010
- I have a canon image runner 3100 color copier, fax, printer. I do not have a service manual to check this error code. It also gives a replace MEGENTA AND YELLOW toner. still getting this error code. error E000020-0191
Posted on Jun 01, 2010
  • Nik Shamsul Nik Mohammad
    this error due to yellow developing have a problem,pull out toner cartridge and try print about 30 copies of yellow single colour(solid) untill machine request for new toner and put back toner cartridge
  • 3 Answers
Have a look at this answer for a solution.
Posted on Jul 07, 2009
  • rpremuz Jun 02, 2010
    BAVITHRAM, have a look at this answer (it mentions the same error code although for Canon IR C3170i ).
    New Friend:
To fix this problem press Additional function,2 and 8 digits at a time then the display board displays copier,feeder,sorter and board. Press on copier and press on ERR>Press on function>Press on clear>Press on ERR>Press OK and restart the Machine By turn off power switch ON.
Posted on Mar 25, 2014
I have Cannon Imagerunner 5000 copier, printer. It show Error E000225-0000. I do not have a service manual to check this error code. Please tell me solution.
Posted on Jul 31, 2013
Hello sir i want to purchase this canon 3100 color/black and white photocopies can u tell its good or other better photo copies
Posted on Jun 08, 2010
    for me this is not good machine because this machine using single drum and rotary unit for four developers and can cause of toner easy to spill off and the output printing also not good enough.
    When toner easy to spill off it can easy give you E020-0081 (patch sensor dirty)
    it true cause i am alread that problem in a most machine so not goog
This problem is caused when the sensor deep inside the machine near the affected toner (in your case, Cyan) gets covered with too much toner, the printer will have to be taken apart pretty thoroughly in order to correct this error so I recommend a Canon certified tech to do this for you.
Posted on Feb 03, 2010
    President:
  • 4,402 Answers
Alors la solution c'est de nettoyer les capteurs sallient par le tonner
Posted on Sep 20, 2012
HI! I have the canon and have the same problem can any body help me what can i do.
Or put to Bin?
Posted on May 21, 2012
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
My canon color image runner c2050 is giving me a code E070-0001 and need to know what to do about it.
The error means that there is a problem with the transfer belt unit. You may need to replaces the transfer belt unit. You may need a service person to resolve your issue.
Oct 09, 2012 | Canon for IMAGERUNNER C2020 C2050 C2058...
We have a Canon Image Runner C2880 with an error code of E00025-002 What does this mean and how do I fix it?
This is error in the toner motor. The 0002 is indicating that there is error in the Cyan developing assembly toner supply. You could try switching one toner motor for the other and see if the error cahnges to the other color. The book indicates that it may be the DC controller as a last resort. Check the connection between the motor and the DC controller. Hope this helps.
0000 is yellow, 0001 is magenta, 0003 is for black.
Apr 13, 2011 | Canon imageRUNNER iR C2880 Color Copier
E000315-000d Imagerunner 3320i error code at start up
E315
A fault is detected when encoding the image data.
1. A chip failure is found when writing/reading/verifying the
image data by using the register of the encoding chip.
FAX failure
2. An error occurs when encoding the image data
Aug 10, 2009 | Canon Image Runner 3320I Copier
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Error code e000007-0000 for a canon image runner 22006
You have a problem with the fixing film. It is not a case that you have to reset the machine and carry on. Replace faulty parts in fixing and then clear the code. Most probably you have a damaged fixing film.
Aug 22, 2008 | Office Equipment & Supplies
Canon Image Runner C3200
YOU HAVE TO SUBSTITUTE YOUR MAIN CONTROLLER
PLEASE, CONTACT CANON SERVICE
Oct 08, 2007 | Canon imageRUNNER C3200 Copier
12,056 people viewed this question
jasbo
jasbo
