Windows stops loading when printer is connected
  • 12,061 Answers
Your printer or possibly the cable is faulty.
Posted on Feb 02, 2010
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Do I need wireless interent to conntect a wireless printer? How do I connect my wireless printer to windows xp? Should it connect just as easy as ''plug and play''? I am having trouble disabling Norton...
You don't need wireless internet, but your computer has to have wireless.
Norton can be problem. You can uninstall it, load the printer, then reinstall.
Feb 28, 2010 | HP Office Equipment & Supplies
LBP2900B DRIVER CD
CANON LBP2900B DriversHere is the driver for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7
Installation Procedure when Connecting USB Cable
Do not connect the USB cable until after you have loaded the downloaded files.
After all files have been loaded connect the USB cable to the back of the printer.
DRIVERS
Thanks & Regards
M. Nanda Kishore
Dec 29, 2009 | Canon LASER SHOT LBP-2900 Printer
Unable to load drivers of samsung 1640
make sure in system windows installer service is running.to check it is running or not ,in run window type services.msc and the go to windows installer option .if it is stop then restart it and then try again.
to install the printer follow this steps,
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Dec 10, 2009 | Samsung ML-1640 Monochrome Laser Printer
Getting "printing application has stopped working"messaage
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark " " Series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows."
To install:
1. Make sure no other programs are open.
2. Insert the CD and wait for the installation window to appear.
3. Connect the USB to your computer when prompted to do so. If an "Add New Hardware Wizard" appears when the cable is connected click on "Cancel."
4. Click on the "OK" button on the Install screen to begin running the software. Follow the prompts and accept the Licensee Agreement to allow the software to load.
5. Once the software has loaded, click on "Finish."
6. Once the software has loaded, you will be able to click "Finish." Your software is now installed.
Aug 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Printer Problem
HI!. Most printers have a self test facility to do a test page without being connected to any PC. If you can find that out from the HP site, that's a first step. Also, check printers in Windows Control Panel to make sure it is the "Default" printer. Try to send a test page. e.g. right click on the icon for the printer, select 'properties' & look for "Print test page". If all these work then next you would open Windows notepad and just type in a couple of rows of text, then print. If that works, then you try your original application program to prove that it is the cause (somehow). Check all physical connections & re-load the s/w driver.
Also, you could take your printer to a friends place that has the same Windows OS and see if it installs OK. Try & test print etc.
Hope this helps you to narrow down the problem.
Jan 06, 2009 | HP DeskJet 890c InkJet Printer
XP refuses to restart after installing printer
It’s not uncommon for software to mess up during installation.
Or even have a bad CD. (Please make sure you're windows XP software is up to date, run windows update service).
Since you are able to get into windows, open control panel, open add/remove programs & uninstall the Lexmark printer software. After uninstall restart the PC. Power on the printer before windows loads. See if windows runs with the printer connected & powered on. Less Its driver software. Windows should see the printer & ask for the software. (If so, it may be corrupted software). Go to Lexmark for driver software & download it.
http://search.lexmark.com/printer/US/en/1410000
Try reinstalling using the online driver software for the X3550 printer. If it still stops you're windows, I would suggest replacing the USB cable. If replacing the cable does not help & windows does not load, there could be something wrong with the printer.
If this is a new printer you should contact Lexmark.
http://support.lexmark.com/static/229-1-0-582.html
Lexmark will suggest all of the above. You'll be three steps ahead of support. Lastly, I have come across an issue from time to time installing printers software into Windows XP systems.
(It matters not the printer model). Windows was missing basic printer files needed to operate any given printer. The fix for those systems was a complete fresh install of windows. Its suggested to never use a copied windows CD. It matters.
Good Luck electrics!
If I can help you further, feel free to post.
There is rarely 1 way to fix every thing.
Mike
May 30, 2008 | Lexmark X3550 All-In-One Printer
Printer trounleshooting
I had windows 98 have new computer windows vista and will not let me use cd to load it keeps closing I need help with new software or something for printer to load on windows vista
Feb 17, 2008 | Office Equipment & Supplies
13 people viewed this question
jasbo
jasbo
