Question about Panasonic PT-47WX49 47" Rear Projection Television
PT47WX52F Convergence problem, 3-d look, green worse
My convergence seems to be off. The pictures look almost 3-d. The green seems to be the worse. I have adjusted the convergence 1 and 2. The convergence one vertical line is lined up on the center mark on top but off a little on the bottom. The horizontal line does not go all the way to the right but seems to be at the marks. It seems like it has shifted to the left. Any advice?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
The picture doesnt seem to be clear and it has a green tint
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Hitachi 46F500 46" Rear Projection...
Double picture & color problem
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
How to get rid of blue ghosting
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 26, 2008 | Samsung HCL4715W 47" Rear Projection...
Panasonic PT47WX52F
those are bridge connectors they stay attached to the A board and release from the D board. Just slide a small screw driver under the bridge on the D board side and gently lift up they will pop right off.
Sep 11, 2008 | Televison & Video
ICS Convergence
Did you also check to make sure both pico fuse are good ?
Jun 09, 2008 | Toshiba 50H71 50" Rear Projection...
Convergence Problem
sounds more like the convergence amp ICs STK392-040 you can get replacements here that comes with instalation instructions.
http://servicemanuals.vstore.ca/
May 22, 2008 | Samsung PCN5425R 54" Rear Projection...
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Toshiba 57h81
Go to the convergence and align the red and blue + - Under Menu then Picture then convergence to get to this screen- Hope it helps
Mar 24, 2007 | Toshiba 57H81 57" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
