Question about Lexmark X2500 All-In-One Printer
Refilled black cartridge 36 on my 5650 won't work
Have refilled black cartridge 36 on my 5650 all in one lexmark printer. It said empty and wouldn't print now it says incorrect right cartridge. Have tried covering the hole on top where I put in ink and have cleaned the copper plate without success. Any ideas?
  • 240 Answers
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
Posted on Feb 02, 2010
  • sabdany Nov 11, 2010
    can you specify what is the "proper technique" ? i would like to try it
  • Pat Anderson
    Pat Anderson Nov 11, 2010
    Lets just say it involves tens of thousands of dollars worth of equipment. Ask your local Cartridge World, they may we willing to show you their shop.
Lexmark c524 eror black cartridge missing or empty
Re-install cartridge or if not original Lexmark cartridge, aftermarket refilled, the printer won't recognize the refilled cartridge.
May 26, 2014 | Lexmark C524 Laser Printer
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
My printers color won't work, I just filled it with 4.5 ml of each color. the black is also really patchy. I want my lexmark z1420 to just work!!! Help!!!
It could be due to the refilled cartridge in your printer. Refilled cartridges tend to degrade print quality and in performance. Try to replace your cartridges with genuine Lexmark cartridges.
Sep 05, 2011 | Lexmark Z1420 Printer
Lexmark x4650 refilled ink cartridge but printer says it's empty and won't print
Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
Jun 14, 2011 | Lexmark X2500 All-In-One Printer
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
I refilled Lexmark ink cartridges 36 black and 37 colored and my lexmark printer 4650 series keeps saying empty cartridges and won't let me print. Can you Help?
36 and 37 can be refilled, but they won't work. They are "return program cartridges" as Lexmark calls them. That actually means that they CAN NOT be refilled. You need to buy 36A or 36XLA and 37A or 37XLA. Those are refillable.
Here is link to Lexmark's site, with a compatibility list.
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+X3650
Hope that helps!
Mar 18, 2010 | Office Equipment & Supplies
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
Lexmark E120 black cartridge
In their determination to keep you purchasing their ink whether you like it or not, Lexmark has circuitry built into their ink cartridges that based on measured use tell the printer when the cartridge theoretically should be empty, whether it is or not.
In the case of the black cartridge they are somewhat more lenient than in the case of the color cartridge. Eventually, when the circuitry tells the printer that the black cartridge should be empty it will continue to be refillable, and work, but will present the owner with annoying messages ranging from "you're using an unauthentic cartridge" to other things. The best thing to do in this case is to check the box that pops up telling it not to continue giving you the annoying messages. This works, but eventually may start again, after which you again check the box telling it to stop. It's quite livable though.
In the case of the color cartridge the built in circuitry will eventually tell the printer that the cartridge is empty, even if it's not because you have properly refilled it, and it simply will not function any longer. You've just wasted your ink. Natually they don't want to see you destroy your printer, which costs less than purchasing only two of their 2400% profit ink cartridges. Good luck.
Jun 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refilling cartridges
For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
Good Luck~~! mstipps@yahoo.com
Jun 01, 2009 | Lexmark X3650 Printer
Reset Lexmark 36 Black cartridge?
I managed to get it working, just damage the connection point (where the chip is). I used a knife to break part of the connection and now I can fill the cartridges myself for a fraction of the price :)
Mar 05, 2009 | Lexmark X4650 InkJet Printer
Lexmark X2500 All-In-One Printer Logo
346 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
