Our Power point Projector keeps shutting off like it is over heating- we are not sure why. It does reboot and start up again- but then again goes off in a few minutes. Any clues of what to look for
  • 77 Answers
There should be a filter next to the fan, you can take it out and clean off all the dust. this will help it cool better. also, make sure wherever you use it, it has clear space round it and away from raditors etc
Posted on Feb 20, 2008
Red lamp or heat light is flashing while projector is off. Can't be sure which it is because it is mounted 16' up. I've cleaned projector & filter with canned air from 12' ladder and red light stops...
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Feb 19, 2011 | Panasonic Projector Lamp for PT-LB50...
Hello, I have a gateway pc that all of a sudden turned its self off, then a 2 seconds later powers up; but it does get to the point of reboot, just to the point where the fans start to spin, then it shuts...
it shows that the power supply may gone bad, not able to bear fan's load,
2nd option is processor gone heat up and restart
3rd motherboard may be faulty
Nov 24, 2010 | Computers & Internet
Projector shuts off after 45min
if the fans continue to run after the lamp shuts off, there may be an overheating issue. blow the dust out it with canned air. the dust keeps in the heat that the projector is trying to expell. also keep things away from the vents. if the fans and the lamp shut off at the same time, you have a power supply issue, usually dried caps due to heat. if it is the power supply, you can send it in for repair or buy the part and do it yourself. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 02, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Cinego is randomly shutting down
if it is overheating, blow out the projector with canned air. excessive dust keeps in the heat that the projector is trying to expell. also, make sure all of the fans are working properly. if it's cleaned out and the fans are running, you may have a main board issue.
Nov 29, 2009 | Radio Shack Cinego D-1000 Multimedia...
My benq projector keeps blowing lamps.
first, blow out any dust with canned air. dust keeps in the heat that the projector is trying to expell. next, don't buy cheap lamps from random websites. you get what you pay for. and make sure you have the correct lamp that the manufacturer states. also make sure there is sufficient space around the projector. the vents cannot be blocked. lastly, reset the settings to factory default. many times there is a low power/full power setting. the fans go on full on high power. there should be at least 2 fans. one for the lamp, one for the optical engine. may be one for the power supply. if the one near the lamp is not blowing much, replace it.
Nov 29, 2009 | BenQ PE8720 DLP Projector
Powers off
clean out the projector with canned air. dust keeps in the heat the projector is trying to expell. once it's blown out, check the fans to make sure they are spinning.
Nov 11, 2009 | Office Equipment & Supplies
I have a Hitachi PJTX100.....been using it for a year and a half and it has been flawless.....until recently....After about 30 minutes of use it shuts off....meaning the screen goes black and the actual...
i believe your problem is heat the bulb is getting hot and the air or fan is not working properly so when it hits temp it automatically shuts off check your fan air flow filters etc
Jan 10, 2009 | Hitachi PJTX100 Multimedia Projector
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Computers & Internet
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Computers & Internet Logo
27 people viewed this question
Alun Cox
David Payne
David Payne
