Question about Hi-Pro (HP-P401W) (HPP401W) Power Supply
I have the HP-2537F3R power supply on a computer. The LED no longer lights up and the computer will not turn on. I think I need to replace the part. There has been some additional hardware added to this computer since we bought it. The present power supply is rated for only 250W. I think I will need an upgrade to 350 or 400 or so. What are my options for compatibility?
  • 348 Answers
Yes there is overload protection to power supply if the power suply is of 250W and load is of 450W then power supply does not work .you have to install 450W power supply
Posted on Mar 08, 2010
My keyboard was struck by lightning. no longer works. tried power supply. any ideas where to start
your computer doesn't power up after storm. does the lights turn on power supply led, motherboard led are they on. are the fans spinning? if its completely dead, the power supply is the place to start. replace with known working power supply if possible. then everything that was plug into it. could of kill one part or the whole system. motherboard or power supply more likely
Aug 25, 2015 | HP PX850AAABBHPLCD 19 L1906 0.294...
Hp computer green light keeps blinking
Green LED light on back of Power Supply?
(The power cable plugs into the Power Supply)
Bad Power Supply. Replace.
Need guidance? I can step by step you through it.
I need the Product Number, though.
This can be found on the Back of the computer, in the white
Service Tag.
P/N = Product Number
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | HP Computers & Internet
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
I have a HPD 2537F3R. When I try to start the computer the green light on the psu goes out and nothing happens
draw the power supply from cabinate then short green and black wire at o/p of power supply then give the power if fan is rotating then power supply is ok if not then faulty. fault may lies between cpu draw the ram and listen the beep contineus beep should be heard then ram is faulty if no contineus beep then motherboard is faulty
Mar 04, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Hp desktop power wont turn on
When you powered it on, does the power supply fan spinning? If not, then you might need to change the power supply. It may got the led light lit on, but it does not have enough power to turn on the entire computer.
Dec 21, 2009 | Cameras
Hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Sep 28, 2009 | HP Computers & Internet
Hp desktop wont start
I think you have more than one problem there. Take it to a local PC repair shop and have them check it out. Five years is a good age for a computer though so you may want to think about buying a new one. Best of the Irish Luck to yer.
Sep 16, 2009 | HP Computers & Internet
Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Aug 16, 2009 | Hi-Pro Computers & Internet
    No longer turns on
    It's well worth replacing the capacitors, but this problem can be caused by a short on the power supply (Which is what the caps do). Most shorts that arise in power supplies are result of a shot transistor or diode and of course the electro caps. Check these while your changing the caps.
    Good luck with it.
    May 25, 2009 | Televison & Video
    Printer will not turn on
    The all-in-one product will not turn on If the all-in-one will not turn on at all, follow the steps below in order to determine the cause:
    1. Verify that there is power at the wall outlet.
    2. Verify that the computer and the all-in-one product have a three-prong power plug.
    3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
    4. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
    5. Plug the power cord into a different electrical outlet.
    6. If the all-in-one has an ADF with an external cable plugging into the back of the product:
      1. Turn off the unit.
      2. Unplug the power cable from the wall outlet.
      3. Unplug the ADF cable from the back of the product.
      4. Plug the ADF cable to the back of the product.
      5. Plug in the power cable to the wall outlet, and turn on the power.
        • If no change, the problem is not the ADF.
        • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
        • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
    7. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
    Nov 12, 2007 | HP PSC 1350v All-In-One InkJet Printer
    Hi-Pro (HP-P401W) (HPP401W) Power Supply Logo
    363 people viewed this question
    Top Hi-Pro Computers & Internet Experts
    Alun Cox
    danielle yancer
    danielle yancer
    Are you a Hi-Pro Computer and Internet Expert? Answer questions, earn points and help others
