Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
I have a Toro S-620 it starts great after i prime it and choke it than it kills. It seems like it just runs with the gas with the prime.
  • 2,926 Answers
Remove the spark plug and verify it is not fouled.
You may also find that the high speed jet and/or port is clogged. This will require the carb to be broke down, cleaned and reassembled. This is common with this type of engine, especially if fue is left in it over time and not drained. Worth a shot.
Posted on Feb 03, 2010
Toro 418ZR runs uneven with choke off
ethanol gas has gummed up your carburetor. take it off and clean it.
Dec 01, 2015 | Toro Power Clear Snowblower 418ZR - 38272
New 621E toro snowblower running on prime fuel has been running now will not stay on with choke out what do i need to do
HOW OLD IS THE GAS . PLEASE DRAIN THE GAS OUT OF BLOWER AND PUT FRESH GAS IN IT I WOULD ASLO GET WITH THE STORE THAT YOU BOUGHT IT FROM TO EXCANGE THE BLOWER
Feb 21, 2015 | Toro Snow Blowers. Power Clear 621E 21 in....
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
I have a Toro 20462 power mower -- about 15 years old, but until just today still running great! The spark plug is good, the gas is good, the oil is good the air filter is good. After priming, it starts...
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
Sep 11, 2011 | Toro Power Lawn Mower
After priming starts, runs and stops
If you over fill the oil your mower will not start until you remove excess oil. This should be checked first, This is a much easier fix.
Jun 20, 2010 | Toro Garden
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
221 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
