Question about HP ScanJet 2200C Flatbed Scanner
How can i unlock the scanner without the little plastic key?
  • HP Master
  • 12,061 Answers
Anything that fits will be OK... depending on shape, you can use a screwdriver.
Posted on Feb 02, 2010
2006 hummer h2 won't start
YOUR KEY (apparently) has a "chip" inside the plastic key body. A "spare key" may unlock the door, but your h2 won't start without the proper "chip" near!
A
May 20, 2018 | Hummer Cars & Trucks
How to remove scanner lock on sharp al-1540cs
If you reach up under the left side of the scanner you'll feel a little clear piece of plastic. It rotates about 90 degrees from locked to unlocked. If you unlock it and you want to permanently be unlocked, just pop the plastic thing off with a screwdriver, but MAKE SURE IT'S UNLOCKED BEFORE YOU DO.
Skelton Business Equipment Houston Copiers
Jul 09, 2014 | Sharp AL 1215 Black and White Copier
Pro-95 scanner can't unlock key pad can't reset can't initialize
my pro-95 has a locked number on the key pad--says=mooo**adl+*30375=bank 0 ch 00 ed: none can you help me get it unlocked ?
Jul 24, 2012 | Radio Shack Pro-95 Handheld Scanner
How do you use the emergency key (small black plastic key hidden inside the fob) to OPEN my 2008 Passat? Is there a place on the door SOMEWHERE TO PUT THE KEY. duh on me, I can't find it.
I found out what to do, there is a plastic covering on the door handle. Click that off and the use the key in the key fob to unlock the door. You can lock & unlock it.
Feb 11, 2012 | 2008 Volkswagen Passat Sedan
Unit is locked, preventing programming.
do u see the little key in the upper right hand corner if so click func and then click the light bulb button that should unlock the scanner if not then u might have to reset the whole scanner by holding down the HOLD button and numbers 2 and 9 while holding all 3 turn the scanner back on and the scanner will be reset to factory settings
Jan 16, 2011 | Uniden BC72XLT Handheld Scanner
The problem I am having is with the door locks, they do lock how they are supposed to it is just that when you go to unlock it the key you turn it to unlock it and it doesnt unlock do you know how i can...
There is a little plastic tab that helps to unlock the rod. If the plastic tab is broken, it won't unlock the door/rod. The best suggestion is to look on craigslist or hit your local junkyard and see if the plastic tabs are intact on one of the vehicle. You can use the models from 1986-1994.
Otherwise, you can lock the door before you close it, hold the handle up. Then, when you need to unlock, you will have to unlock with the key, the back hatch, crawl in and unlock the driver's side lock to pop all the rest.
Dec 25, 2010 | 1988 Nissan Pathfinder
The other lock
If the key is removed, the lock is gone from it.  It's just a clear piece of plastic in there.  What could be causing the L1 to happen is the ribbon cable underneath the scanner glass is out of place causing the scanner to stall.  This is a common problem with the AL copier line.  You can take the scanner glass off and check the cable for any binding going on with it.
Sep 07, 2008 | Sharp AL 1215 Black and White Copier
Key stuck, now new problem
There is a pin that goes thru the shift cable that is falling out. Above the window buttons pry the little plastic holder out remove the 2 screws take the plastic off of the sides of the console you will see a black plastic frame with holes in it I cut a larger hole between 2 of the small holes with a hack saw on the driver side. Put the car in neutral drivers seat all the way back pull on the shift button and you will see the pin pull it out with a pair of needle nose pliers. I put 598 black loctite sealant on mine and reinstall. Shift back to park if you can get the key out and the doors unlock you have the pin in the right spot and it is making both switches when in park. You can see if it is on the switches by looking thru the hole where the little holder came out. The pin sticks out about a 1/2" on each side. Good luck
Aug 25, 2008 | 2006 Chevrolet HHR
Canoscan lide 60 drive cord problem
Drive cable is attached in two places. One at the hinge end of the scanner. The other at the control panel end. The hinge end connection is a simple ball-end that slips into the slot. The control end fixing is more complicated. The wire cable at this end has a spring attached. This is fixed to a plastic fitting which clips into place. Look carefully the plastic fitting. Fit the spring over the small peg and take the cable round the radiused part of the plastic fitting. And refit the plastic clip to the scanner body.
c21b280.jpgFiddlly but doable.
The cable often comes loose when someone investigates how to take the scanner to pieces. Underneath they see a round pin with a small rectangle on each side. They press the round pin in slide the piece of plastic in the rectangle and hey presto they'll undone the cable. Oooops!!!!!!!!
Mar 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
How to restore locked out channel
Hi your scanner may be locked. if on the screen it has a small K/L symbo, then it is locked. to unlock it press the lock button and it should go away. now press the L/O key if there is a little L/O key that is on the screen. this should unlock out the channel. hope this helps A.Ryan ant_man-92@hotmail.com
Sep 19, 2007 | Uniden BC60XLT Handheld Scanner
HP ScanJet 2200C Flatbed Scanner Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
