Question about RCA R52WM24 52" HDTV Projection Television
Black spaces on both sidE of picture - RCA R52WM24 52" HDTV Projection Television
  • RCA Master
  • 12,061 Answers
Depending on the Aspect Ratio set, this is normal?
Posted on Feb 02, 2010
Where can I buy a Defond CPU-2113 safety switch for a Toro Blower/Vacuum?
If you do not use the Blower / Vac for Vac you can cut out the the reset switch, it's only when you get foreign material in the impeller using the Vac stopping the motor, I cut out the switch. As you look at the Defond switch (side with writing you see a white wire and a black wire side by side. mark the black wire with a small piece of tape 1-1/2 inches from the connecting lug. Cut all wires off the switch. Strip wires back 3/8 to 1/2 inches. Use heat shrink tubing
and slide it back on the black wire with the tape, same thing thing with the black wires on opposite side of the switch. Use a end to end splice as opposed to a parallel splice because of wire routing space..Splice the white wire with the black with tape, Then the other two black wires. using heat shrink tubing to cover the splice. Good idea to take a picture (smart phone) so as to see wire routing after you separate blower halves, very little wire routing space. Make sure motor is seated in it's nest before joining halves together do not use Vac if you use this fix. Mine works just fine, save $60+ bucks.
Nov 01, 2014 | Toro Garden
Picture is not full screen
select the 16:9 aspect ratio in the settings to have full picture.
Sep 27, 2012 | Dell W4200 42 in. HD-Ready Plasma...
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Picture display format doen't fit 32'' screen
if you have cable box or a sattelite change the resolution of the STB to 4.3
Feb 06, 2009 | Sanyo DP32746 32 in. LCD Television
Offset picture
You need to change the Display menu for picture mode to 16:9
no wide fit or scan fit.
Jan 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Panasonic tv TC-26LX60 PICTURE PROBLEM
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Nov 15, 2007 | Televison & Video
Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
Sep 22, 2007 | LG RU-44SZ51D 44" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
