Question about Car Audio & Video
Original wiring of Clarioan PE 662B Cassettte deck
What are the color of the original wires and where did they connect?
Thanks
  • 1,868 Answers
Hello! Unfortunately none of the wiring schematics are available for free...
You can find a manual at the following link:
samswebsite.com/photofact/pf_search.asp
Cost is $22...Sorry I did not have better news...
Guru...............saailer
Posted on Feb 03, 2010
Need color wire coding for delco model 16176761 in 95 camaro. casette deck quit so I bougt after market radio but can't interpret color of wires attached to original radio - which color is hot, which...
Try going to (not calling) your local PARTS DEPARTMENT at your local dealer,. they should be able to print you a copy to go..
Best regards
Ck
Please provide feedback ratings
Oct 03, 2011 | 1995 Chevrolet Camaro
I need a wiring diagram for a 2010 Jeep Wrangler Stereo, I'm trying to install an aftermarket deck.
If it isn't already cut, please do not cut the factory connector off the wires that plugged into the original radio. Instead, puchase the correct pigtail for your vehicle, it will plug right in to the connector from the factory radio and colored wires that match the wires on the deck come out of the pigtail. This simplifies everything and leaves you with the option of reinstalling the factory radio at a later point.
Feb 28, 2011 | Car Audio & Video
My 2003 Durango has an after market trailer hitch on which the wiring converter has literally exploded leaving me with no tail lights and fried wire ends on the vehicle side of the converter. Since I am...
You should not have to rewire anything.
Hitch wires are just "pig-tailed" on to the original vehicle wiring. Just cut off the hitch wires cleanly and tape the cut end.
You have probably burned out the stop and tail lamp fuses also. Read you owner manual for fuse location.
Please rate is answer by checking the "Hands" below. Thanks j
Feb 09, 2011 | 2000 Dodge Durango
1990 toyota corolla stereo wiring codes i just purchased a sony stereo and i took out the old radio in my 1990 toyota corolla but i cant figure out how to connect the wires i need the color code for...
what you need is to buy a wiring adapter for your car.it only cost about 15 bucks and plugs right in to your original plugs that were connected to your factory radio.the great thing about this adapter is that you dont hava to cut your original plug off just in case if you ever want to reinstall your original back.also the wires that go to your new headunit are color coded to match the exact colors that you connect to your stereo.you can't mess your connection up because all you have to do is connect each wire to the right color,tape them up,connect your stereo and you have music with all of your speakers working like they should and without any headaches.i hope this info helps.take care and good luck, manny
Jul 12, 2010 | 1990 Toyota Corolla
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
Mar 12, 2010 | 1992 Ford Probe
I want to change my original cd player for a pioneer
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
Dec 24, 2009 | 2003 Ford Explorer
I've got a 1988 Dodge Ram and I know nothing about Car Stereos
go down to a electronics shop (future shop or best buy) and they will have a connector that will fit the original plug. Some splicing will be required but its all color coded with the deck
hope this helps
Nov 15, 2009 | Alpine CDA-7840
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
Remove audio deck from 2003 Astro
It is very easy: With parking brake applied, shift to 1st gear, then remove the dash panel that goes around the instrument cluster and the stereo. Once the panel is off, you there is a black tab on both of the side of the unit that you push down, and then pull the unit out.
To install an aftermarket deck, I recommend a specific wiring harness adaptor, that you splice onto the connector included with the new deck - so that you can reinstall the original one if/when you want to sell the vehicle. If you don't, you have to cut the original harness wires, and connect them in the correct orentation (which is tough, as there is about 20 wires!)
Apr 29, 2009 | 2003 Chevrolet Astro
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
