Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
My ch25-730 has one of the cylinders exhaust pipe turning bright red at a medium rpm. What would cause this problem? The other remains normal. This engine has only 6 hours on it.
    Champion:
  • 243 Answers
Hi, please check valveclearence
Posted on Feb 15, 2010
Testimonial: "I will check them out. Thanks"
I have a 05 chevy impala check engine code p0036 n p0142 bank one sensor two which sensor do I replace
If you have access to a scan tool, check the signal voltage for the Bank 1,3 oxygen sensor with the engine at normal operating temperature. Is it stuck low currently? If so, increase RPM for a few seconds and see if it affects the reading. If it begins working with increased RPM, check for holes in the exhaust near the O2 sensor that may cause a false lean. If the exhaust pipe is intact, the sensor is sluggish, replace it. If the Bank 1,3 O2 sensor voltage reading remains low with increased RPM, unplug it and then observe the reading. It should have increased to about 0.5 volts or thereabouts. If it did, check for water intrusion or other connector problems. If none are found, replace the shorted O2 sensor.
Jul 14, 2011 | 2005 Chevrolet Impala
Exhaust pipe turning red right out of cylinder shortly after cranking
your pipe is not original use original if it does not over heat its normal ..
Jan 18, 2011 | Yamaha RD 250 Motorcycles
The exhaust pipe at the cylinder head on my 2009 DYNA glide glows bright red, is this a problem with exhaust not leaving the pipe fast enough? Also, I think I have an exhaust leak on the same pipe.
I have an XLCH1000 that had the same problem. I fitted finned exhaust clamps at the cylinder end and that cooled it down.
Ride safe and loud pipes save lives.
Dec 15, 2010 | Harley Davidson FXD Dyna Super Glide...
I have caterpillar disel genretor of 456kva capacity,when i switch on generator within halfhour of running it's EXHAUST MANIFOLD AND TURBINE GETS RED HOT. i am not able to understand why gets red...
It is quite normal for the exhaust manifold and turbo to get very hot, especially when the engine is working hard running at high speed under load. Every time the mixture in the cylinder is ignited there is a small explosion producing a BIG flame and a lot of heat to push the piston down. A lot of this heat goes out the exhaust. During daylight it is usually not noticeable, but at night it will visibly glow up to a bright red.
In relation to the oil pressure dropping, providing the oil level is at the correct level, there may be a restriction in the gauze filter on the input of the oil pump due to sludge buildup. Once the engine warms up and the oil thins out, the oil pump can't work at maximum capacity. The drop in RPM could be caused by the turbo getting insufficient lubrication and cooling due to the low oil pressure reducing oil flow to the turbo causing it to not work at its optimum speed and efficiency and therefore through reduced air flow into the cylinders the engine would tend to loose speed especially when under high load. The drop in RPM could also be caused by a problem with fuel flow to the injector pump causing the engine to run lean which would not allow the engine to produce maximum power and also contribute to higher exhaust temperatures because the governor would have the throttle wide open to try and maintain the engine speed when the generator is required to produce maximum output.
Oct 29, 2010 | Heating & Cooling
My car is a 89 toyota corolla the engine is a 2E my problem is at hi speed the exhaust turns red which you dan lite up acigarette .what do you think could cause this type of a problem
It is quite normal for the exhaust manifold to get very hot, especially when the engine is working hard running at high speed under load. Every time the mixture in the cylinder is ignited there is a small explosion producing a big flame and a lot of heat to push the piston down A lot of this heat goes out the exhaust. During daylight it is usually not noticeable, but at night it will visibly glow up to a bright red.
Oct 21, 2010 | 1985 Toyota 4Runner
How to change an exhaust on a ford focus 1.6 16 v
there are rubber mounting underneath the car, remove there.
follow the exhaust pipe to the engine, loosening any bolts and nuts holding the exhaust in place.
the exhaust pipe meets the exhaust manifold close to the engine. loosen it there and replace,
the part remaining on the engine (also a much thicker pipe than the pipe) is the exhaust manifold. this must the loosened at the engine itself. normally two nuts per cylinder and your car being 4 cylinder its 8 nuts.
There nuts can be dreadfully tight though, it gets hot there so the expansion and cooling of of the studs and nuts tend to make them tighter over time
Oct 11, 2010 | Ford Focus Cars & Trucks
Exhaust red hot,why?
It is quite normal for the pipe/muffler connected to the engine exhaust port to get very hot, especially when the engine is working hard running at speed under load. During daylight it is usually not noticeable, but at night it will visibly glow up to a bright red.
Sep 08, 2010 | Craftsman Electrical Supplies
Left exhaust pipe is turning a gold colour for approxiamtely 12 inches from the engine
It is normal. One cylinder & pipe are a bit hotter than the other. It is not at all unusual to see one pipe discolored more than the other.
Apr 27, 2009 | Suzuki Boulevard S83 Motorcycles
VTX1800R-03 exhaust overheating
did you re-jet when you put the pipes on? a too lean mixture can cause pipes to glow red hot
Apr 01, 2009 | 2008 Honda VTX 1800 T
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
256 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
