Question about Maytag MER5770 Electric Kitchen Range
I have a Maytag MER5770AAW replacin element
I have a Maytag MER5770AAW and the right front outer element does not work the inner one does . Do I need to replace the dual element and how do i do it?
So is it the element or the switch???????
Posted on Dec 10, 2013
  • 725 Answers
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
Im replacin the cv joints on passanger side and driver side how do i get the axle out of the transmission casing is ther a key behind the plate with the 4 bolts? my truck is a 99 isuzu rodeo LS 4wd
remove inner cv boot, just on inside edge is circlip which holds inner bearing joint into outer housing remove circlip and separate joint outer housing does not come out of front diff unless you drop or remove whole front diff assembly
will have to remove whole stub axle hub assembly to remove drive shaft from outer wheel stub axle (hub) assembly
Apr 20, 2011 | 1999 Isuzu Rodeo
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Maytag Range MER5730AAQ front right burner died
you need to replace the inner connetor to make it work.
Jun 24, 2009 | Maytag MER5730 Electric Kitchen Range
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5770 Electric Kitchen Range Logo
253 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
