Question about Haier HTE18WAA Top Freezer Refrigerator
Continuing fridge problems
I appreciate your prior responses regarding my less-than four-year-old Haier refrigerator problem. They were very good answers, unfortunately I do not seem to have gotten to the root of the problem as of yet.
It started with the refrigerator warming, and you correctly led me to the fan behind the freezer wall stopping because of frosting. While the fridge and freezer are at acceptable temperatures at the moment because you helped show me what to look for, the frosting problem seems worse than ever.
The defrost circuit appears to be operating fine on its own (though it could have been stuck before as I did manually move it), with it turning on every ten hours, warming, melting, and then turing off, and yet within a very short period of time after that a good deal of frost/ice forms within the air louvers of the freezer that I need to constantly clean out, on the freezer coils and the back wall of the freezer, and elswhere in the freezer. The fan occasionally stops again but I can get it started with a little helping push. I am stumped.
Although the fridge and freezer are not abnormally cold, I am not sure if the compressor is turning off at all in between defrost cycles. I just turned the thermostat to its lowest level for a quick test and the compressor remained running, but I do not know if that signifies anything or whether that could be connected to the seeming abnormal amount of moisture and quick frosting once the defrost cycle is completed (it is the middle of winter here, very dry). The doors are sealing just fine.
One thing I inadvertently did when recently removing the freezer door was to lay it on its back with a puddle of water in it, not thinking anything of it at the time. Well a fair amount of moisture got into the door insulation through little pin holes that I could barely see. I know I did not get it all out after discovering the problem and I do not see a way to easily take that door apart and dry it out more thoroughly. I am somewhat skeptical as to whether this could be causing or contributing to my problem, especially since the problem seemed to start before I had that door off, but I just do not know.
Any suggestions would be greatly appreciated. I thank you very much.
  • kostuj Feb 19, 2008
    I just tried lowering the thermostat again and this time the compressor did turn off, so it appears that could not be the cause of the problem. Thank you again.
  • kostuj Mar 12, 2008
    I thank everyone for their comments, and you surely saved me from a service call.
    I kept an eye on the problem for a while, and I still kept getting a great deal of frost/ice build-up in the freezer louvers, with the condensor fan quitting on occasion. Though I was not confident that a weak condensor fan could cause such symptoms, I had my eye on that part the most, and when I felt it binding when turning the power off and moving it manually I took the chance and purchased a new fan. The new one is circulating at seemingly five times the speed of the old one and the frosting has disappeared. Upon removing the old motor and checking it out further, it was very bad and stopped almost as soon as I spun it.
    I thank you again, as I have my refrigerator back (at least for the time being) at the least amount of cost solely because of your help. Even so, at $50 for the new motor after less than four years, I now wish I would have put that money toward a better model/brand of refrigerator at the start. My particular Haier is put together like the Johnny Cash song "One Piece at a Time." But who knows, maybe it will go twenty years now. I appreciate everyone's comments.
    Problem Solver:
  • 10 Answers
Your freezer is probably not sealing prolly. make sure the door is perfectly lined with the box. You might want to change the defrost timer from the 10hr you have to a 6 hr timer. In high humidity areas too much frost tends to accumulate causing the vents, and the drain line to be clogged. That might be why you have the puddle of water. The ice that is defrosted every 10 hrs runs down that drain line to a pan on top of the compressor, if that line freezes up, all subsequent water from defrost ends up in the refrigerator or freezes in the freezer.
Posted on Mar 08, 2008
Hi I have a refrigerator Haier #HA10TG205S The fridge is not working, but the freezer is? HELP! it is only a couple of years old?
Check the adjustment arrow has not shifted on the theremostat, they also have a 36 mth warranty.
Sep 25, 2016 | Haier Refrigerators
GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Feb 16, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Ge refer not blowing cold
Hello mancoder,
Welcome
You said, your GE TBX 23Z refer has been working fine. moved it to assist in tile install. place back, plugged in starts to blow cool then after 2 hrs it blows room temp. It is clean dust free in under carriage and has plenty of air space. Fan blows very strong. I do hear a click and then 2 -4 seconds later another click. This continues every couple minutes. Sounds like poss the compressor is trying to engage? Not sure? It is older but a very nice unit and blows well, any ideas?
It sounds like the compressor to me!
in a fridge that is ten years old or more it is not worth the investment of putting good money in to bad.
The newer fridges use a lot less power and your utility bill will go down
It will pay for itself in only a few years!
Here is an article I just read that you may find useful and interesting!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Let me know what you decide and if you have any more questions
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Oct 19, 2008 | Refrigerators
My fridge stop cooling including the freezer section, motor is running okay. This is a icemaker fridgedair. Help , please.
Hello kenbarn
Welcome to Fixya
You said,
your fridge stop cooling including the freezer section, motor is running okay. This is a ice maker Frigidaire. Help , please.
What is the model number?
And how old is the fridge?
First try to unplug the fridge for 5 minutes and then turn it on again and see if we reset the system.
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Oct 05, 2008 | Frigidaire Refrigerators
Freezer works but frige dosent get cold enough.
Welcome to fixya richarddl53,
You said, you have a side by side about fifteen years old need to know what type freon to charge it with.
The freon that's used in the old refrigerators is not legal now!
They started using a newer kind of freon years ago that does not deplete the ozone layer.
Yes you are low on freon, but that's because you have a leak somewhere.
And if by chance you could acquire the freon that you need to add into the older model fridge, it will just leak out again shortly!
My opinion is that you should not put good money into bad!
A new refrigerator uses less electricity than a fridge that is ten years old.
And yours uses 10% more than that!
you will see the differents in you utility bill as it will pay for it self in a few years!
I just read this report you may find interesting.
Repair or replace?
Thank You, HUUUM
Sep 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Sep 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge not cold
ice build-up on the back wall indicates a defrost issue, check the defrost items. check the defrost timer, the defrost heater and the defrost thermostat, if you need more details let me know.
Apr 02, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Haier HTE18WAA Top Freezer Refrigerator Logo
176 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
