Where is the video card located and what does it look like
  • yadayada
    yadayada May 11, 2010
    what is the system u have, make and model.
  • 360 Answers
There are two type of video adapters, a card type and integrated.
Integrated is when it is part of the motherboard. Card type is when it is a expansion card that is installed onto the motherboard.
Easiest way to tell which you have is by where you connect your monitor to your computer. If you connect by all your USB connections, mouse/keyboard connections then it is integrated...you can not replace it unless you replace the motherboard.
If you connect your monitor further away from the above mentioned, then you are most likely using a card type of video card. Here is a picture of what an installed video card would look like. The video card is the part that has the "small" fan on it. The left side of the picture is the back of the computer.
http://tech.icrontic.com/draco/images/articles/tech_tips_5_vga_cooler/ws_installed.jpg
Here is a picture of an uninstalled video card.
http://en.wiki2buy.com/images/7/77/Video_Card.jpg
Hope this helps you.
Posted on Feb 02, 2010
Where is my WiFi Card located on a Gateway M305crv laptop? I purchased a BroadCom BCM94306 Mini Pci Wireless WLAN Wifi Card as the specifications indicated. Now I don't know the location of the WiFi...
Hard to explain so video shows where it it most likely located on bottom of laptop
see this video to see in first part of video 5 min 18 seconds where the wi fi card plastic cover it located on bottom of laptop
https://www.youtube.com/watch?v=oFwzdP216Cg&list=PLoQ4NWSN36fECZjaAGHCflBAPBAOm5gAL
I would recommend using ESD precautions that are not observed in the video link above
https://www.youtube.com/watch?v=R-I8XGdrD5w
ALSO TAKE out POWER CORD and LAPTOP BATTERY ! Before attempting fitting
Aug 11, 2015 | Gateway Computers & Internet
Where is the video card located at in the box?
Some machines have the video built into the motherboard.
Best way to tell is look at the Video port on the back of the machine.
(Where the monitor cable plugs in)
If the Video connection point is in within a card slot it is easy to spot what position and where. If the Video connection port is in line with the motherboard. It is built into said motherboard. And yes if you have an available slot open you could upgrade the video should it be built into the motherboard.
Here is a link for slot types
networking ringofsaturn com
Hope this helps.
May 24, 2014 | E-Machines eMachines Desktop PC
I need to install a video card on a Sony VAIO VPC-EA36FM. I need instructions., video, etc.
Instructions
    • 1
      Make sure that you have the latest drivers from the manufacturer of your new video card.
    • 2
      Remove the video drivers for the current video card. Check the Start menu for any Remove utilities specifically for the current video card.
  • 3 Remove the current video card in the Device Manager. Now you're ready to install the new video card.
  • 4 Turn off the computer and disconnect it from the power source.
  • 5 Follow directions from the computer's user manual to open the case. In most cases, you'll just remove a side panel.
  • 6 Locate the AGP video slot. If there is a video card in it, remove the video card.
  • 7 Orient the new video card so that the metal bracket lines up with an open slot in the back of your computer and the gold contacts on the video card line up with the opening in the AGP connector.
  • 8 Push the new video card into the AGP slot with steady, gentle pressure.
  • 9 Connect any power cables to the power supply.
  • 10 Secure the video card in place with a screw through the card bracket into the computer case.
  • 11 Close up the case, following the computer manual's instructions.
  • 12 Reattach the power cord, monitor cable, keyboard and mouse.
  • 13 Power up your computer. Windows will detect the new video card and ask if you want to install it now. Click "OK" or "Yes."
  • 14 If prompted, direct Windows to the directory where the video drivers are located. Follow the prompts to install the drivers for the new video card.
  • BMW ACCESSORIES.
    May 31, 2012 | Sony VAIO Computers & Internet
    How do transfer pictures from internal memory to card?
    Got this from the manual.
    Copying pictures/videos
    You can copy pictures/videos from a card to internal memory or from internal memory
    to a card.
    Before you copy, make sure that:
    ? A card is inserted in the camera.
    ? The camera’s picture storage location is set to the location from which you are
    copying.
    Copy pictures/videos:
    1 Press the Review button, then the Menu button.
    2 Press up and down arrows to highlight Copy , then press the OK button.
    3 Press up and down arrows to highlight an option.
    4 Press the OK button.
    Apr 14, 2010 | Kodak V803 Digital Camera
    How do I locate the video card in HP Pavillion 15.4 6000
    The video card is what your monitor is plugged into. If it's plugged into the motherboard then your video card is built in and can't be removed or replaced which is one of the drawbacks to proprietary systems like HP. You can plug another video card into one of the slots in the motherboard assuming you have the right video card to fit the slot in the motherboard. IE PCIE, PCI, AGP.
    Nov 05, 2009 | CMB T43 750 Notebook
    My computer screen goes black alot, sometimes white with weird microsoft ballons of misc information in the background. I changed moniters but it doesn't solve the problem. Where is the video card...
    The problem is not on the monitors, but came from you AGP card, The video card located on AGP slot, try to release and plug again, if the problem still the same, replace your graphic card
    Oct 20, 2009 | Gateway GeForce2 MX400, (64 MB) AGP...
    Yes i need help with my memory card i have it in my computer now i am tryin put videos on it what do i need to do..
    Locate the video in the folder that you have your video. insert you SD card, open SD card drive folder and right click your video file, select copy then right click SD card folder and select paste
    magic!
    Oct 06, 2009 | PNY 2GB microSD Memory Card
    Need to replace the pc card on model pcv7764
    There is no such thing as a pc card. If you are talking about a video card, it's a PCI video card and it is located inside the case. Your monitor will plug into it on the outside, so open the case, remove the screw securing it to the back of your case and gently pull out the card.
    Jun 15, 2009 | Sony VAIO VGC-V520G (VGCV520G20TVPC) PC...
    Memory card extraction....
    CHECK OUT THIS YOU TUBE VIDEO IT SHOWS WERE THE MICRO SD MEMERY CARD SLOT IS HIDDEN BUT IT SHOWS THE LOCATION OF IT, http://www.youtube.com/watch?v=UFN5cNpo7p4  JUST Look at the full video it helps by locating it, good luck
    Mar 08, 2009 | HTC G1
    I'm trying to locate my video card inside my PC. I have a Medion 7309c Model. Whenever I power my system unit on it goes through the boot process and then goes to a blank screen, so i believe that my video...
    Most home user PC's of the last while now have onboard video cards so you would need a new motherboard if the video card were bad. Good news it it's likely that the system's drivers just failed. If you boot to safe mode with networking support you know it's just drivers. When booting with networking support you can find a new driver for your video card or even simply remove the video card from the device manager and reboot. Sometimes the latter works, as just a single file was corrupt and needed to be recopied. If this doesn't work you can start looking at the RAM (since thats technically your video memory). It can be as simple as a bad connection so you can just blow the slots out w/ an air compressor (canned air is too weak) and reseat the RAM. Otherwise test your RAM in someone else's system or get some RAM and try booting. Last of course is the motherboard which hopefully isn't the case for you.
    Nov 12, 2008 | Medion Computers & Internet
    Computers & Internet Logo
    129 people viewed this question
    David Payne
    David Payne
