Question about Pioneer AVIC-F700BT Car GPS Receiver
Keeps shuting off when i start my truck it comes on where it says pioneer then shuts off but the fan in the back stays on
    Problem Solver:
  • 5 Answers
You might want to check the pioneer website to see if there is a patch download for temperature control. If it's not that then I would check the VCC connections to your unit. It might not be getting all of the power it needs...
Posted on Feb 04, 2010
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
After furnace shuts off fan keeps running and blows cool air for while before shuting off
Check the AFC AUTOMATIC FAN CONTROL is not blocked with fluffon the back of it , you can remove this and check the back of it .
Mar 15, 2013 | Heating & Cooling
How do i put more antifreeze on my hhr
How long does it run after shut off?Does it shut off at all or just run forever? If it ends up shuting off at some point after shut off, then I wouldnt worry to much bout it. The fan will run until the temperature sensor tells the computer that your engine is cool enough whether car is off or not. If it never shuts off then that'd be different : ) can honestly say I haven't seen that b4 but I'd say start at the temp sensor chk for voltage readings and see if they are within specs for your vehicle. Maybe sending constant signal to computer. Hope this helps you out.
Jun 28, 2012 | 2006 Chevrolet HHR
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Keeps shuting off
If the receiver shuts down after some time operating properly it is likely caused by a heat issue or crossed (shorted) speaker wires. Please make sure that the unit is adequately vented and the air vents/fan on the back of the receiver is clean. If it is then carefully check all of the speaker wires for cracks, damage, and/or crossed wires.
Feb 26, 2009 | Yamaha HTR-5630 Receiver
Pioneer SD-P55A3-K Proj TV will only stay on if I run a fan behind it...
Thermal issue !
A component inside the set has a thermal issue !
This may require hours of trouble shooting to find the components responsible.
Once the component(s) are found they could be serviced.
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | Pioneer Televison & Video
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer AVIC-F700BT Car GPS Receiver Logo
329 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
