Question about Toshiba 55H70 55" Rear Projection Television
Tv turns on but any bump or significant vibration kills the screen and power light starts flashing
  • Toshiba Master
  • 12,061 Answers
You have an intermittent connection, or a "Dry Solder Joint" or perhaps a Plug that is loose.. These can be real hard to track down. You are going to have to take it in for repair to a reputable repair.Service center. Get a firm "Quote" for repair.Shouldn't bee too costly though.
Posted on Feb 02, 2010
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
MY TV FLASHES 7 TIMES ON THE POWER/STAND BUTTOM
ensure the lamp cover door is firmly pressing the kill switch and the red light will stop and u can turn on the telly
Jul 05, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Acoustic solutions tv flashes coloured screens when turned on
Can you measure the screen VOltage.How many volts.
Check Power module distribuition voltages.What do you mean by ac
oustic comes from sound do you mean Vibrations?
Nov 04, 2012 | Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Tv isnt turning on, you will hear a click then see the power light flash 6 times then the light goes off for about 10 mins then comes back on flasing again...and the cycle just continues. It did this once...
Sounds like a power supply problem. I worked for a short period for Panasonic at their USA plasma R&D / small scale manufacturing facility and learned that to "ignite" or start the plasma when turning on the set, a significant current discharge is required.
The recycling seems to indicate that the "brain" in the set realized that a plasma has not been established, and it is attempting to recharge the starting circuit. The flashing power light is probably significant and a trained technician or a service manual will probably identify this as a trouble code pointing to the problem. Sorry, I did not have any exposure to the finished product and cannot advise what the code means.
If the set is still under warranty, you should act immediately and get the problem taken care of, because it will not go away on its own, and will most likely get worse. Sorry the news is not better. Good luck!
Jan 28, 2011 | Panasonic Viera TH-42PX80U Plasma TV
The front suspension on Dodge Ram 1500
If your not hauling a load reduce you tire air pressure, will give a little more smoother ride, also under braking have your front brake rotor checked they might be wrap.
Jun 04, 2010 | 2006 Dodge Ram 1500
TV will not turn on
Sounds like the power supply needs replacing.
TV repair is best done by a pro unless one has significant experience with it.
Charlie
Aug 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
HL-P5063W vibrating and won't turn on
i have had this happen to me several times in the field, and if it is what i think it is, you are not going to be happy =(
inside of a DLP type TV, there is a device called a 'color wheel'... it is essentially a disc made up of different colored glass that spins really fast. this disc has 3 or 6 (depending on make/model) pieces of colored glass like pieces of a pie affixed (read: glued) to a hub.
what happens sometimes is that one of the pieces of colored glass flys out of the hub, and causes a massive unbalance in the spinning wheel, which causes the hum/vibration, and since the colored glass is missing, the colors will be all messed up.
if this is what happened, then your television will require a new DLP engine.
Dec 08, 2008 | Televison & Video
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Toshiba 55H70 55" Rear Projection Television Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
