Question about Microwave Ovens
REMOVE WALL MOUNT MICROWAVE
CANNOT REMOVE OVEN
  • 3 more comments
  • capt_bob1954 Feb 19, 2008
    KENMORE
    MODEL # 564.8775380
  • capt_bob1954 Feb 20, 2008
    Hey,
    Thanks to all for assistance. There is a flat brace that runs up both sides of the wall mount . You can just see the top of it. At the bottom, is a set screw that goes thru a retaining bracket, Once that is removed, and remove the bracket, you can pry down on the brace till it pulls out of the top retainer. The unit will now tip forward. Be careful, this one was quite heavy.
    Have a great day and thanks again,
  • Thomashigh Mar 09, 2008
    Need to replace our microwave oven. Cannot figure how it is mounted in our RV. It is a Sharp R-1480 mounted under the counter. Have looked for some kind of brackets but found none.
    Please email me.
    Thanks for any help you can give me.
  • okok1 Dec 10, 2008
    I have a Sharp R-1851A Microwave oven on wall mounts ... how do I remove it??
  • William Miller
    William Miller May 11, 2010
    Please give us your brand and model number so we can help you.
I have a microwave oven in my kitchen, want to take it out
Posted on Jul 23, 2008
  • Microwave Ovens Master
  • 9,098 Answers
TO: capt_bob1954:
You can find an exploded view of the outer case & installation parts for the 564.8775380 model here. Maybe that will help.
If not, on that same page, it shows where you can order a copy of the installation instruction manual for $4.99. It's probably worth it to save a lot of aggravation.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO: Guest
You can find an exploded view of the outer case & installation parts for the 665.68601891 model here. Maybe that will help.
If not, on that same page, it shows where you can order a copy of the installation instruction manual for $9.99. It's probably worth it to save a lot of aggravation.
Posted on Feb 20, 2008
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing Microwave
First I would wonder if you really need to remove it from the wall? Many repairs can be done with it still in the wall. If so, installation instructions should be with the paperwork that came with the oven, and that will show you how to remove it. Buit if you don't have that, you would likely remove the grille from across the top. The grille is usually held in place with screws and/or clips. After that is out, there may be a couple of other screws now revealed at the top edge, or there may be a one or more "catches" just under the top edge of the the chassis. I would strongly advise you to have a helper working with you. These can be heavy, and awkward. You might call the GE Answer Center and ask if they can supply you with installation instructions. They're at 800-626-2005 (24 hrs.) Otherwise, you may be able to find instructions that are close enough at a place like Lowe's. They may have some demo models and you can usually ask to look at the manuals.
Posted on Jan 07, 2007
MicrowaveSvc
  • 9098 Answers
The installation guide will show you how it is installed and you can download that here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%204358149.pdf
If that link's a problem, just look it up under the Owner Center section here: http://whirlpool.com/custserv/index.jsp
Posted on Nov 26, 2007
SOURCE: How do i remove the
hello I am trying to remove my microve from the wall I did remove 2 bolts on top,I am non able pull
the unit out.anybody can give me suggestion. dave
Posted on Oct 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Posted on Jan 11, 2010
How do you safely remove a ge spacemaker microwave oven from its wall mount?
This is a two person job. You have to have one person holding it and the other takes the screws out from the cabinets above the unit. There should be two screws that are inside the cabinet that hold it up against the bottom of the cabinets. When those are loose you can slide the unit forward on the rails that attach to a large wall bracket. Or some use a lift type latch to the wall bracket.
Apr 26, 2015 | GE SpaceMaker Microwave Ovens
How to remove ge spacemaker xl
You want to take the microwave off the wall, is that correct. 1st unplug the microwave--plug should be in the cabinet over the microwave. Next--in the same cabinet you should see 2 or 3 phillips head screws with big heads going through the bottom of the cabinet into the microwave top. Have someone hold up on the microwave while you remove the screws. They are about 3 inches long. Once the screws are out, the microwave should tilt forward and downward at the front. The back of the MW sits on 4 tabs on the wall mount plate so to get it off completely you have to lift the back up slightly off the tabs about 1 inch. Feed the power cord down through the cabinet and you are done.
Feb 28, 2015 | GE Profile Spacemaker XL 1800 36"...
Electrolux wall mount micro wave oven combo doesn't work
Good Morning Friend,
I understand that your Electrolux wall mount microwave oven combo is not working. I see that the oven is working, but the microwave is not. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux EI30MH55GS Microwave Oven
LG LMV1680ST no upper mounting
Look for back mounting bolts location, find your wall studs location and mount from the back
Apr 23, 2012 | LG LMV1680ST Microwave Oven
I need a wall mount bracket for a ge spacemaker micro, but I have no model #
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Sep 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have ge under cabinet microwave model jvm1331 004 that i need to remove. what holds the unit in place?
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
May 25, 2009 | Kenmore 63792 Microwave Oven
Need New Microwave
Is the interior flaking the only problem with it?
It can be sanded smooth and clean and dried thoroughly, then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, if you want to replace it, I would suggest contacting Jenn-Air Customer Care here and telling them your model number.
They can probably give you the model number of a new "drop-in" replacement.
Dec 12, 2008 | Jenn-Air JMC7000 Microwave Oven
Sharp Microwave R-1480 ~ Removing
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. There are chrome or a gold color. That is the only other way that they mount to the wall.
Good Luck
Nov 17, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
1,533 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
