Computer keeps rebooting
I recently decided to upgrade the RAM in my computer from 512mb to 2gb which is the maximum my motherboard will hold. Well, I can run 1gb fine and I can run 1gb stick and a 512mb stick fine as well. However, whenever I insert a second 1gb stick it will run for about 15 minutes then reboot and it will show a message that states "Windows has recovered from a critical error."
Some have told me it could be either power or cooling problem so I went ahead and bought a new case that has seven 120mm fans cooling it and a new 1000W power supply and nothing has changed. Could it be windows or something else?
    President:
  • 4,402 Answers
You either have a bad memory or bad memory slot!
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
I have Compaq nx6310 and i want to upgrade my RAM ... both my 2gb ram modules work but if they are both in my laptop it wont turn on ... before i had 2 x 512mb ram modules and those work well ... even...
This is from the NX6310's documentation:
Intel 945GM Express Chipset supports up to 4096-MB maximum (2048-MB
533- or 667-MHz SODIMM in slots 1 and 2)
Intel 940GML Express Chipset supports up to 2048-MB maximum (1024-MB
Basically if you have the Intel 940GML Express Chipset, then the machine only supports 2gb of ram as a maximum, to confirm this, go to Start > right click computer/mycomputer > go to manage > device manager > system devices.
Under there you'll see what chipset you have, if it's the Intel 940GML Express Chipset, you're out of luck, if it's the Intel 945GM, you may just have the wrong speed ram, make sure they are the same speed and compare them to the spec above.
Thanks,
Liam
Sep 16, 2013 | HP Compaq nx6310 Notebook
My motherboard has 2 slots that can each hold up to 512mb of ram with a maximum of 2gb, so how am I supposed to max it out...?
What motherboard is it.
If you can find the makers name and model number on the board you can usually find it on the makers website and download the manual for it. That should tell you exactly the right configuration for the ram.
Jan 23, 2012 | Gateway Computers & Internet
Can I install more than 512mb of memory on a Presario s5300nx. I actually want to do 2gb or more. If so, how can i safely do it w/o messing up my computer. Thank you.
> I want to do 2GB or more.
As the Rolling Stones sang, "you can't always get what you want".
See: http://www.memorystock.com/ram/CompaqPresarios5300nxRAM.html
which states that your motherboard has 2 RAM slots, with a maximum of 512MB per slot.
So, how many RAM slots currently are empty, and how much RAM is installed?
If you currently have 2 sticks, at 256MB/stick, you will need to remove both sticks, and install two new sticks.
If you currently have 512MB of RAM, and one empty slot, then that web-page describes the exact type of RAM that you can insert into that empty slot.
Jun 26, 2011 | Computers & Internet
I have intel D865GBF mother board with the support of Hyper threading Technology with 512MB RAM....now i want to upgrade the ram to 1 GB .....So my question is , can I use 1GB DDR2 RAM in this motherboard?
One easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM memory you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity for each individual slot is, as well as the maximum total RAM that the motherboard can handle.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to buy in order to maximize the memory capacity and performance of your computer.
Thank you very much and good luck.
Mar 29, 2011 | Intel D865GBF Motherboard
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Hello
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Not to exceed manufacturer supported memory
Good Luck, and do rate the solution if got help
Dec 24, 2010 | Gateway GT5220 PC Desktop
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I purchased my computer in 2001 with an intel D845GLLY motherboard. the ram was 256 mb. When I upgraded the systemthey said the max. Ram is only 512MB & so we upgrade ram to 512MB. I am surprised to...
I want to answer your question but I would need so many other questions answered. Topping of my list of necessary things to understand about your situation would be to understand why you would want to spend any time or money on this system? Are you going to actually use it after the ram upgrade? If so your money would go a lot further getting a used 2010 computer which would still be obsolete but may come with the 2gb ram right right from the factory. Maybe you should hit your local Craigslist and grab a $20 computer or take one a friend is sending to be recycled?
Dec 11, 2017 | Intel Desktop Board D845GLLY Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Upgrade ram
hiya
this board is ddr so you will need ddr400 or pc3200 and a maximum capacity of 2gb so be carefull with 1 gb sticks as sometimes this causes system crashes
hope this helps
Regard Rik
Feb 26, 2009 | Intel D101GGC Motherboard
Motherboard capacity
Can you get me the motherboard Model number ?
Dec 16, 2007 | Intel Motherboard
Computers & Internet Logo
157 people viewed this question
Alun Cox
David Payne
David Payne
