Question about Sony Cyber-shot DSC-HX1 Digital Camera
Can't open Multi Connector cover. Brand new camera. Can prise it up slightly but I feel I will do damage if I continue. Help please! I forgot to say - camera is a Sony Cyber-shot HX1.
    Brigadier General:
  • 11,967 Answers
You won't damage it...just open it.
Posted on Feb 02, 2010
Iphone4, how to open battery
Make sure you turn your phone off before you remove the battery. There is 2 torx head screws, 1 on either side of the charger socket on the end of your phone. Remove these, you then slide the back cover up slightly to remove the back cover. You then have to remove 1 phillips screw which holds the battery connector, be careful as there is a small metal guard under the battery connector which could fall out without you noticing. You then prise the battery connector up with something plastic to avoid shorting out the battery. The obvious sign that your battery needs replacing is when the battery status goes down to 12 or 10 percent and the battery dies before getting down to single figures.
Dec 31, 2013 | Apple iPhone Smartphone
P2113 throttle pedal position sensor
remove the four screws holding the cover on the electronic portion and as you prise open the casing,very gently and only slightly you will be greeted with a cup of engine oil,you need a new throttle body
Nov 20, 2013 | Kia Sportage Cars & Trucks
How to open the samsung B2100 cover?
You continue to turn it past the unlocked symbol. This makes the cover raise itself a little so you can prise it off.
Jan 08, 2010 | Samsung B2100 Cell Phone
Tefal aquaspeed 260 No heat no light. Fuse OK
I had the same problem. Turned out to be dirty contacts on the thermostat, easily cured with a strip of sandpaper, but you need to dismantle the iron first.
  • Remove the 3 Torq screws in the heel plate (the purple triangular bit at the back, that you stand the iron up on when it's cooling off). One of the screws is a security screw so you'll need a special screwdriver, though I suppose you could risk drilling it out if you're desperate.
  • Prise off the bottom section of the heel plate, to reveal the cable connector block. Pull out the connector block (it's just a push fit).
  • Pull out the self clean / steam selector button.
  • Prise off the white plastic front cover (the one under the self clean button, that surrounds the jet spray nozzle).
  • Under the cover are 3 screws that hold the sole plate and iron body together. Undo them.
  • Now you should be able to separate the main components of the iron and get to the thermostat. Check the contacts - mine had a build-up of carbon from the arcing as the thermostat operates. Clean both faces with a strip of sandpaper, then reassemble the iron, being careful to align the temperature selection lever correctly.
Dec 22, 2009 | Tefal Irons
Charging system problem
sounds like the stator may be grounded
May 14, 2009 | 2000 Harley Davidson FLSTC Heritage...
Keys not working
i had the same problem once. I forgot my handy e61 was at the back pocket of my pants while i drove home from work. the keys would work, some of the keys got so pressed that they were stuck, it did took me time to unstock these keys by opening my phone. Just be carefull on opening the phone. pls.
Aug 19, 2007 | Nokia E61 Smartphone
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Maintain all-weather capability
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
All-weather
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
All-weather capability
The following steps can be taken to maintain the all-weather: Make sure that all the covers are closed before using the camera. The camera loses its all-weather capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Saltwater spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. If the rubber packing becomes worn or damaged, contact the nearest Olympus service center to obtain a replacement part.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Sony Cyber-shot DSC-HX1 Digital Camera Logo
82 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
