Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Hi: I need to adjust the number of rings before the fax answers? what do I do ?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Hello main229,
It may be useful to check the help menu in the sowftware that was installed with the SUPER G3 FAX BOARD-T1. It usually shows how to set the amount of rings befoe the fax answers.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Feb 02, 2010
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
Hi. When my house phone rings more than three times my fax machine trys to answer the phone making conversations inpossible. How do i get my fax hp1040 to answer only my fax's?
The fax is set to answer on the 4th ring. Change it to answer on say... 6 rings.It cannot differentiate the call before it's picked up ... it just answers at at set number of rings
Apr 01, 2011 | HP 1040 Plain Paper Inkjet Fax
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
How can I adjust the number of rings after which
Turn printer power on.
1 Press Setup.
2 Press 3, then press 3 again.
This selects the Basic Fax Setup menu, then selects the Rings to
Answer
option.
3 Press Enter.
4 Press until the desired number of rings before answering appears on the front panel display.
5 Press Enter to accept the setting.
Also you can download the manual for this machine by clicking here:
http://h10032.www1.hp.com/ctg/Manual/bpu05029.pdf
Hope this helps.
Mar 05, 2010 | HP PSC 950 All-In-One InkJet Printer
How do you set up the rings for a lexmark fax machine lexmark 6570
Setting Auto Answer to on
From the desktop, double-click the Productivity Studio icon.
2 From the Welcome Screen, click Fax History and Settings.
3 From the “I Want To” menu, click Adjust speed dial list and other fax settings.
4 Click the Ringing and Answering tab.
5 From the Auto Answer drop-down list, select On.
6 Click OK to save the setting.
The Auto Answer light on the control panel comes on. When the number of rings you set is detected, the printer
automatically receives the incoming fax.
Hope this fully answers your question. Best of luck.
Greg
Jun 26, 2009 | Office Equipment & Supplies
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Unreceivable
Manual can be found here: http://www.samsung.com/support/productsupport/download/FileView.aspx?cttfileid=526982&type=Multi+Function+Printer&typecode=16&subtype=Laser+MFP&subtypecode=&cmssubtypecode=1601&model=SF-5100I&filetype=UM&language= Does the unit ring at all? If it does do the following (taken from the manual) Receiving automatically in FAX mode 1. Press Rcv.Mode/Contrast until the display shows ?FAX MODE?. 2. When you get a call, the machine answers the call on a specified number of rings and receives a fax automatically. You can change the number of rings. See ?RINGS TO ANSWER? on page 5.4. To adjust the ringer volume, see ?Adjusting volume? on page 2.8. If the phone is not ringing, then the call is never even getting to your fax machine. Hope this helps If you need more information, please ask before rating this solution. Ed
Jun 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
253 people viewed this question
old marine
old marine
