Question about Epson Office Equipment & Supplies
The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I can check it. there is a plastic rule across the front of hte paper feed I cant remember seeing this before so dont know if this is part of the problem
  • Epson Master
  • 511 Answers
Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
Posted on Feb 03, 2010
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
A paper jam problem keeps coming up and I'm unsure of how to fix it, I've replaced the paper and checked the printer, however it continues to jam. the paper when pulled out has a crease on the...
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Jun 14, 2011 | Epson Stylus CX6900F All-In-One InkJet...
PRINTER IS SAYING THERE IS PAPER JAMMED AND IS NOT FEEDING PAPER THROUGH BUT I CANT FIND THE WHERE THE PAPER IS JAMMED OR HOW TO ACCESS THE ROLLERS WHERE IT MAY BE JAMMED PLEASE HELP
Jan 24, 2011 | Canon Pixma MP450 All-In-One InkJet...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Display ... ''clear paper jam''
First clear the possible paper jam using a air blower on the rollers and sensors most possible cause is the paper dust which block the sensors. then do a power cycle by unplugging the cable and leave it turned off for 5 mins and then reconnect, it should take care of the issue.
May 04, 2009 | Canon Office Equipment & Supplies
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Canon imagerunner 2230
YOU HAVE A PROBLEM WITH THE PAPER FEEDING CENSOR. IT COULD BE OUT OF PLACE, BROKEN, A PEICE OF PAPER STUCK OR PULL OUT THE DRAWERS MAYBE PAPER STUCK INSIDE. GOOD LUCK
Aug 04, 2008 | Canon Image Runner 3320I Copier
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
RECURRING PAPER JAM - BROTHER MFC 5860 CN
I just bought the 5860 and have this issue right out of the gates. I discovered that the back lid causes the paper jam when using the bottom tray while examing with a flash light during a print job. I dislodged the back plate/lid (same lid you remove to pull paper jam out) out about 10mm and fastened the lid loosely to the back with a piece of tape on each side. The paper from the bottom tray does not slam against the back of the printer any more, thus more freedom of movement and no jams. Just successfully printed an 80 page document. You shouldn't have to do this with a new printer but I got it so cheap with all the rebates that I'm going to keep it and live with this fix. To sum up, the problem is a design flaw where the removable back plate is snapped in too tightly and contacts the bottom tray paper roller (& paper) during a print cycle. To fix you need to clear the path by pulling the back lid out slightly and taping each side with scotch tape to 'suspend'the back plate out about 10mm.a5999d3.jpg
Feb 02, 2008 | Office Equipment & Supplies
266 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
