Question about HP LaserJet 3700 Printer
What did I need from cable to connect with the computer
  • 231 Answers
Should have a USB port, and a ethernet connection
Posted on Feb 02, 2010
Help me to connect 2 dell computers with cables
The easiest method of connecting any computers is to use a router which will also provide a DHCP server component to serve up local TCPIP addresses to each connected computer.
To connect to the router you would need standard ethernet cables which are available widely and which would plug into the network port of the computer and the other end into the port on the router. You need one cable for each computer to router connection.
If you have computers with WiFi / wireless capability, then you would need a wireless router and could then connect without the need for cables.
Take a look at the Practically Networked web site which has revies of various types of routers and also provides tutorials on networking and other related subjects which would help you.
Jan 04, 2012 | Dell Dimension Computers & Internet
Tip
Using a crossover cable to connect two computers.
Hi.
You can use a crossover cable to share files and folders between the two computers.
A crossover cable looks exactly the same as any Ethernet cable, but its internal wiring is reversed respect to the regular cables used to connect computers to routers or switches.Crossover cables have the 1st and 3rd wires (counting from left to right) crossed, and the 2nd and 6th wires crossed, thay can be recognised because the word Crossover is printed on top of the cable.
Before proceeding ensure that the cable you are using is a crossover. Crossover wiring isdifferent. By using an ordinary ethernet cable you will not be able to extablish a directconnection between computers.
To use the crossover you will need to disconnect any other cable connection to computer ethernet cards. Naturally both computers must have a wired network adapter installed .
After connecting the crossover, you will need to configure the network connection.
Turn off both computers, connect the crossover (cat5 or cat6) cable, and turn back on computers.
Ensure that all firewallare turned off, and on Vista answer yes to all requests of authorization for the new network.
On both computers go to system properties, and ensure that the two computers have the same workgroup.
Second step is going to Sharing and Security, in system properties, and sharing the files and folder that you want to transfer.
Once the folders are shared you will see in My computer (Computer on Vista) the folder shared from the other computer. Simply copy and paste the files.
You may be asked to restart computer after each step.
If after sharing files and folder you want to share Internet connection, then you will have to assign two IP addresses that are in the same range to the two connected computers.
An IP address is a series of numbers from 1 to 256, in the format XXX.XXX.XXX.XXX . The two IP addresses must share the first three numbers to share the internet connection. In the real case, you can set the IP adresses to 192.168.0.1 and 192.168.0.2.
See also:
Connect two computers using a crossover cable
on May 26, 2010 | Computers & Internet
Tip
How to connect two computers using a crossover cable.
Hi.
A crossover cable looks exactly the same as any ethernet cable, but its internal wiring is reversed respect to the regular cables used to connect computers to routers or switches.Crossover cables have the 1st and 3rd wires (counting from left to right) crossed, and the 2nd and 6th wires crossed, thay can be recognised because the word Crossover is printed on top of the cable.
See also:
on May 25, 2010 | Microsoft Windows Vista Ultimate Edition
Jan 04, 2012 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
Networking with xp n windows7 system
If you are connecting directly from computer to computer, you need a crossover cable (Cable specific to direct computer to computer connection) otherwise you need two cables and a hub/switch/router to connect.
Jul 05, 2010 | Dell Inspiron 1525 Notebook
I DON'T KNOW WHERE TO PUT WHAT WIRE TO CONNECT 2 COMPUTERS
You connect the phone line to the router, then you connect ONE PC to the router via an Ethernet cable and configure router, after that you can remove that Ethernet connection and connect wirelessly.
Feb 10, 2010 | D-Link AirPlus DI-524 Wireless Router
Cable modum not detecting PC activity????
Unplug the power from your cable modem. Turn off your computer. Make sure there is a network or usb cable connected to the computer from your cable modem and they are connected properly at both ends (if usb use the back ports on the computer).
Plug the power back into the cable modem and wait 1 minute. Turn on your computer. Check connectivity by trying the Internet.
If you still do not have connectivity, try these things in this order:
1. Update the drivers for your network card through your computer/motherboards manufactuar website.
2. Replace the network or usb cable and try again.
3. Contact your cable provider to make sure they can see your cable modem on the network.
If you need to connect via PPPOE, usually this only applies to some DSL clients. It is reccomended to use the install disk that came with your modem so you can set up your username and password correctly to connect. If you need additional information on this, contact your ISP for configurations.
Have fun.
Jan 29, 2010 | Computers & Internet
How to set up for xbox live connection
You need to connect the cable to an internet modem or to a router. you dont conect the xbox to the computer.
The cable is suposed to have both ends exactly the same. the reason why you cant't fit it in your computer is becase you probably allready have a cable with internet connection going to the computer, so connect the cable going to the computer to the xbox or get a router an connect that cable to the router and then get two more cables to go to the computer and other one to the xbox
Dec 27, 2008 | Microsoft Xbox 360 Console
HP LaserJet 3700 Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
