Question about Royal VF1000MX Shredder
My PX110MX will not turn on, if I hold the on/off button down I can hear the reverse motor run but the forward motor will not run.
    Genius:
  • 1,218 Answers
If you can hear the motor run that is a good thing....however there is only 1 motor...it does both jobs running backwards and forwards....if it runs backwards the motor is "probably" ok and the problem is with the pcb inside...call Royal at 1-800-524-0799 for parts assistance.
Posted on Aug 29, 2010
EZGO Electric. Motor runs but will not go in forward or reverse.
It sounds like you may have a sheared keyway or pin on the input shaft to the differential. It is highly unlikely that all of the teeth could be stripped from the pinion gear. If you pull the motor loose the problem should be very easy to find.
May 15, 2017 | Cars & Trucks
What is wrong when the electric driver seat in a 1995 ford mustang will not move forward or backward but will move up and down.
check switch for proper operation //check motor control for power ,connections and wires are not damaged or disconnected===check seat track for debris or something stuck
Aug 11, 2015 | 1995 Ford Mustang
Model 2000 fs. Red light flashes when forward or reverse is pushed. hear the motor click when the button is pushed. lost reverse then would not go forward shortly after.
Turn the dial-a-speed down to half-way. If issue continues check motor wiring. The click is likely the brake disengaging - which it should. If motor is okay (under 2 ohms) then you likely have a bad speed pot and/or engager assy.
These are wear items and are usually replaced every 3-5 years.
Sep 26, 2013 | Pride Health & Beauty
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
It is jammed. It will not turn in forward or
Soak the clog with hot soapy water to dissolve the paper. Seriously
Oct 13, 2009 | Fellowes Powershred C-320C Shredder
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
Jumps up and down at rear when braking
check front motor mounts. Hold brake and put in reverse then accelerate and let up on gas. do yhe same in forward gear.if you hear a thud a motor mount is broken with hood open you can see the motor lift up.. Acceleration causes engine to lift and drop. good luck
May 10, 2009 | 1990 Dodge D150
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Royal VF1000MX Shredder Logo
160 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
