Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a new sears garage door opener but the range or distance for the remote is right infront of the door .my old one i could use from the end of the driveway. i have moved the wire around and tried adding on a longer piece still no luck
    President:
  • 3,197 Answers
Here are some things you can look for and try but if your opener is new it should be in warranty. Call Sears service.
Limited range of your remote controlscould be related to radio frequency interference that comes fromsomething in your home or in the surrounding environment. Certainelectrical devices can radiate interference; this could be almostanything that is plugged into an electrical outlet.
Please keep in mind that the device canbe brand new, or can be an item that has been in use for quite awhile. Also, the item may continue to function properly as far asyou are able to tell. The only problem with the item may be that ithas started to broadcast the interference, with no other symptomsnoted.
Some devices are more likely togenerate interference than others. This includes TV cable, cableamplifiers, surge protectors, fluorescent lights, battery chargingdevices (power tools, golf carts, etc.), anything that utilizes atimer (sprinkler systems, lights, alarm systems, etc.), and a myriadof others. If the problem seems sporadic, we can safely assume thatthe device responsible for the interference is only being operatedduring these times. Again, please keep in mind that the age of thedevice does not determine if it is capable of broadcasting unwantedinterference. Any electrical device can be the source of the problem.
The first step is replacing the batteryin your remote. If the range on your remote does not improve, removethe wall control wires from the overhead unit. If the range does notimprove you will likely need to replace the remote control. Afterreplacing the remote, or if you have other remotes programmed in tothe opener, and the range problem still exists, please proceed to thePower Down test.
Multiple garage doors:
If you have two garage door units andone is working just fine, you will need to start by unplugging thegood unit. This will help determine if the unit with no range startsto function properly. If the range comes back to the bad unit thenyou will need to replace the logic board on the unit that wasunplugged as it is emitting an RF signal that is over powering theother garage door opener. If the range doesn not improve after the“good” unit has been unplugged, replace the batteries and tryprogramming some additional remotes to determine if the existingremotes are the issue. If the extra remotes do not have any rangethen you would need to replace the receiver logic board in the “bad”unit.
Power Down test:
To isolate potential sources ofinterference, turn the circuit breaker off to the garage and plug thegarage door opener into an extension cord from another room. If therange improves, then the interference is coming from a device in thegarage. If no improvement is seen follow the same procedure, thistime turning off the circuit breakers to your home, with theexception of the garage and test the remote controls. If improvementis noted, turn the circuit breakers back on, one by one, until therange problem resurfaces. This will allow you to narrow down whatroom the problem device is in. You will have to go from there toisolate it further, by unplugging and re-plugging the items in thatroom.
If you are unable to determine anysource of interference, then the receiver logic board in the overheadunit will need to be replaced.
Posted on Feb 02, 2010
I purchase a new garage door opener and my old remotes wont work with it I have 4 old remotes
If it came with its own remote (probably), then you'll have to use the new remote with it - they're all keyed to individual garage door openers, as it should be; otherwise, anyone could use any old remote to open your garage door.
Aug 13, 2014 | Sears Craftsman LiftMaster Chamberlain...
Bought house with craftsman garage opener. Owner only had one remote. Bought a new remote at Sears that matched color code. followed instructions to code remote...that worked but made the old remote non...
Post the model number of the opener and the model numbers of the remotes. The opener model number is found on the end closest to the door and starts with 139.
Try programming the keypad like this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
After programming the keypad see if either remote will work with it. Post this information also.
Oct 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Nnew Sears garage door opener - old keypad
Yes,buy the new keypad in the safe side.Probally have new Inferred signal codes by the new remote might work with the old keypad.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my old remote to work with my new garage door opener
buy new remotes. New opener is 315 mhz, old are 390 and not compatible,
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
CHAMBERLAIN WILL NOT RESPOND TO REMOTES FROM STREET.
Sounds like "cross talk" interfence from the other operator. You can get a plugin external reciever that should work with your current remotes. Try to get as much distance as you can between the working operator and the new reciever.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Receiver
COULD BE A WEAK REMOTE BATTERY A BAD REMOTE OR A BAD RECEIVER.
YOU CAN BUY AN EXTERNAL UNIVERSAL RECEIVER. THAT CAN BE MOUNTED CLOSER TO THE DOOR AND IS CHEAPER THAN REPLACING THE CIRCUIT BOARD.
BUT REMEMBER, I HAVE SEEN A RV POWER INVERTER PARKED NEXT TO THE GARAGE STOP A NEW OPENER FROM WORKING AT A DISTANCE OF 5 FEET.
SO I ALWAYS SUGGEST TURNING OFF POWER TO EVERYTHING YOU CAN JUST AS A TEST.
HOPE THIS HELPS
Oct 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door remotes
Tilt antenna different direction. Call Liftmaster for advice
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
138 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
