Question about Refrigerators
Leaking Maytag Model MZD2766CE
Have you heard of problems with the Maytag Model MZD2766CE freezing up in the back of the freezer and leaking water out front of the unit? Thank you.
    Sergeant:
    Champion:
  • 263 Answers
Your drain line is clogged. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
Posted on Feb 05, 2010
Testimonial: "Thank you! Does this happen often?"
How do I repair water leaking in the bottom of the freezer on Maytag model MBF2258XEW
Check your door seals. The air gets in, the moisture freezes then the defrost cycle turns it into water.
Sep 14, 2014 | Maytag Refrigerators
Msd2757ae freezer leaks water
Leaking Refrigerators Just What may Be Happening
I am pretty sure you are having a defrost drain blockage problem, and click here=>
Leaking Refrigerators! Let me know if helpful, Sea Breeze
Feb 23, 2012 | Maytag MSD2756G Side by Side Refrigerator
Side by Side Maytag SS-2, water is leaking into bottom of freezer side and freezing, eventually leaking out.
defrost the freezer and remove the ice . then with hot water & a turkey baster force water through the drain in the back // when clear the problem is over .. this is caused by algi build up in the bott om of drain line .. mm
Jul 10, 2011 | Maytag Refrigerators
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaking in freezer Maytag MSD2651HEQ side by side
you need to open the back of your freezer there is a hole for drain in the bottom...
clean it with hot water and pump so that way you clean the path to the drain pan next to the compressor.
The path might be frozen so use hair dryer at first... good luck let me know if you need more help.
Arik
Jan 11, 2010 | Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
