Question about Stanley 46 - 050 10 - 3/4" x 6" Quick Square Adjustable Layout Tool
How do you determan the 1 to 12 angle marks on the square to find the right compound cuts cheers
    Guru:
  • 509 Answers
The 1 to 12 marks are the rise of the roof pitch in 12 feet. 1 would be 1 foot rise in 12 feet, 2 would be a 2 foot rise in 12 feet and so on to the max of 12 foot rise in 12 feet.
Posted on Feb 03, 2010
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
What is a compound miter saw?
A compound miter saw has a rotating vertical pivot allowing the cutter head & blade to be tilted (or beveled) sideways in addition to the horizontally rotating table. This allows vertical & horizontal angled cuts as well as cuts angled in both planes.
Jan 28, 2013 | Saws
My blade is not square to the table i,e if I make a 90deg cut, it is about 1/16 wider at the top of the board than it is at the bottom. I've lost my owners manual and was wowndereing holw I go about...
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
Apr 25, 2011 | Makita 10" Dual Bevel Sliding Compound...
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
May 19, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How to cut compound miter on a flat surface, where can I find the chart.
It's a combination of an angled mark on the board and the bevel on the saw set to the proper angle. What are you trying to cut?
Jan 28, 2010 | Delta Saws
How do you adjust the saws angle cut? When it is sett at 0 degress it is not making a square cut.
take a framing square sit it on base plate and adjust till its square and level with that angle.works same with table saws also hope that helps ya
Nov 28, 2009 | Hitachi C12LSH 12" Sliding Dual Compound...
I bought a protractor to measure the angle fo my stairs for baseboard. Now that I know thw angle how do I apply this to make the right angle cut?
Use a framing square with a set of angle gages (or stops) on it. The protractor can be used but it will take a lot of flipping and changing. The normal settings are 8" rise and 10" tread.
Oct 18, 2009 | General Tools 17 Square Head Protractor
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Stanley 46 - 050 10 - 3/4" x 6" Quick Square Adjustable Layout Tool Logo
611 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
