Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
When I play back recorded video on my Sony HC20 video cam, Grey horizontal bars overlay the recorded video seen on the camera screen.I have used a "head cleaner tape" but did not work. Suggestions anyone? Thanks- J.H.
Video recording is correct but recorded video is unable to see on video camera screen. Please guide what to do?
Posted on Feb 11, 2013
    Problem Solver:
  • 10 Answers
Try using wet head cleaning tape. If no solution then need replace the video head if you can't do, go to service shop to change it
Posted on Feb 03, 2010
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Sony handycam DCR-HC20 Screen blank
i want driver of sony digital 8 ready shot camera
Jul 06, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Viewing Problems
this is caused by the guides being out of alignment, needs to be serviced.
Jan 25, 2008 | Sony Handycam DCR-TRV140E Digital...
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
No image in the viewfinder or LCD screen when try to record...
I have recently had what I think is the same problem. I wrote to a supplier in the UK to see if they could diagnose it from my description. My camera is still not fixed as yet (as I have not sent it off yet for fixing), however there initial analysis was that it is 'Drive PCB' problem and a replacement part would cost £38 + labour + tax. I am not sure what the Drive PCB is, but I have the same blank/grey screen when trying to record but playback is OK. My camera is also about 2 years old.
Apr 07, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
379 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
