have you connected the 4 pin molex plug from the computer mainboard to the drive ?
is the IDE Cable correctly fitted ?
did you set the jumper connector on the rear of the drive to Master Or Slave ? if you are sharing the cable with a hard-drive, and the hard-drive jumper is set to slave, then the dvd will have to be set As Master ( otherwise they conflict ) or only 1 device will be recognised.
This should Solve your problem here.
Mike @ Compurepair.
hello sir/madom my name is palamkuttalmathai i did not use any cdearth software but november28...
(More)
hello sir/madom my name is palamkuttalmathai i did not use any cdearth software but november28 cdearth took 38 pound from my mastercard do you can helpme that i can get that money back to my account
IMAC 10.3.4 I know this is an older mac but it meets my needs. I live rurally and am still on dial...
(More)
IMAC 10.3.4 I know this is an older mac but it meets my needs. I live rurally and am still on dial up. Any help is gratefully appreciated.
My dvd burner will burn the image up to about 96% then it says failure to write image is there...
(More)
My dvd burner will burn the image up to about 96% then it says failure to write image is there something wrong with the burner or the software? This has happened with various softwares that I've used to burn images. I get the same results.
