We are trying to print labels from the bypass feeder for the DP-C262. No matter which way we feed in the labels, they are printing the opposite (for example, we say portrait, they print landscape). Very frustrating. Any suggestions.
Yes - we went through the settings on the printer through the control panel as well as setting them in the page set up feature in Word. It seems like the copier itself may have a setting somewhere and it overrides the drivers on our computer???Yes - we went through the settings on the printer through the control panel as well as setting them in the page set up feature in Word. It seems like the copier itself may have a setting somewhere and it overrides the drivers on our computer???
I'll check that - thanks! I've also contact our rep to see if we have the most current print driver loaded onto it - maybe there is a newer version that may help. Thanks - I'll check the copier setting.I'll check that - thanks! I've also contact our rep to see if we have the most current print driver loaded onto it - maybe there is a newer version that may help. Thanks - I'll check the copier setting.
The copier is networked - I'll try the ip address and see what I can get! ThanksThe copier is networked - I'll try the ip address and see what I can get! Thanks
You can't post conmments that contain an email address.
Just a thought. On some features, so that you can distinguish between a fax and print, copy and print, so that the orientation of the paper comes out different for print,fax,copy etc, there is a rotate image 90 degrees setting.
Not exactly where that would be on that model, but sounds like that is a real possibility on your settings.
the other thing i just thought of, is the copier on a network and if so usually they have a web based browser, just type the ip address of the printer with http:// in front and review the settings there the other thing i just thought of, is the copier on a network and if so usually they have a web based browser, just type the ip address of the printer with http:// in front and review the settings there
I gather that you are trying to feed through the bypass tray? if so does it feed normal A4 paper?.If it feeds normal paper then it sounds as if the feed tyre is slipping and requires cleaning.I would suggest that it is cleaned anyway and also check that there is no obstructions in the feed path.
you need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
you may have to set the lables up on the bypass or manual feed input as the machine has to compensate for the thickness of the labels and slows the print process down. check the display on the copier it may be asking to load labels in the bypass
something else you might try is taping the card to a full-size sheet of paper, so the printer can push it through with ALL the rollers at the same time. not all printers have a roller all the way across, so index cards get snagged by one side, and they'll walk to the opposite side while they're printing.
Hi nwillett, Yes and no, sorry if that doesn't make much sense. For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/ The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels. However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them. Regards Taminol
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer 2. Turn on the printer power. 3. Allow the printer to feed or error out. 4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button. 6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead. 7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation. 8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Have you gone into your print driver and changes the settings there?
I am not sure with your inormation if you have changed the settings on the printer or in the driver.
What it sounds like is happening is that there is a mismatch between the printer and computer.
It may even be set so that it is looking for lables in a bypass tray.
Somewhere there is a mismatch in information as to where the labels are loaded.
Start at the driver properties page and confirm every step in your setup.
Solution Title:
How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/SResolution/ Solution
Fixed! Did not fix.
Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN.
In Microsoft Word (Word 2000)
Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
Under Printing Options, select Portrait (LEF) - Long Edge Feed
As Feed from, select Tray 5 (Bypass)
Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
Under the Paper/Output tab
Set the following features as follow:
Job Type: Normal Print
Paper Size: COM10
Output Size: Same as Paper Size
Image orientation: Portrait
Image Rotation: OFF
2 sided Print: 1 sided Print
Stapling: None
Output destination: Center Output Tray
Offset Stacking: None
Under Tray/Layout
Set Paper Source to Tray 5 (Bypass)
Click on Bypass Tray Settings
Paper Type: Heavyweight (1 or 2)
Feed orientation: Portrait
Click <OK>
" on Specify Paper Type and select Heavyweight (1 or 2)
" (Apply> and <OK>
" <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6)2006-04-05 21:57:29
