Question about Precor C954i Commercial Treadmill
Err 22 keeps displaying on control panel on one treadmill and on another err45 ..... Any answers? Plus some treadmills same to just trip, have to keep switch them back on!
    President:
  • Precor Master
  • 832 Answers
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started
Possible Causes 1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. 2. Drive motor brushes are bad. 3. The speed sensor position relative to the speed sensor target is incorrect. 4. The speed sensor potentiometer adjustment is incorrect (when equipped). 5. The speed sensor is inoperative. 6. The lower PCA is bad. 7. The lower PCA to upper PCA interconnect cable is bad. 8. The upper PCA is bad
Error 45 :The lift control system has detected that the lift is moving in the opposite direction of the issued
Possible Causes 1. Lift Motor hysteresis. 2. Bad lower PCA
Possible Remedies 1. This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor. 2. This is a very rare condition, if the lift moves in the opposite direction of the issued lift command, replace the lower PCA lift command.
Posted on Mar 02, 2010
Incline in lowest position, will not move. Shows ERR on display panel
If you wish to get some details; check the site linked here. Pull up older posts...........
http://electro-medical.blogspot.com/
May 06, 2016 | Spirit Fitness Spirit XT685 Treadmill
How come the circuit breaker keeps tripping when i push the start button on my treadmill
Before you give up on the unit check the AC wire (while unplugged) at the way to the control panel and or motor. It could be defective somewhere along the way especially where it passes through a hole or up through metal tubing.
Mar 02, 2015 | Horizon Cst 3.5 Club Series Treadmill
Hello, I have a Paradigm T801 showing the error message ERR 40 Over Acceleration. Is there any easy fix for that problem?
Reset the machine and proceed wit this steps. God bles you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 02, 2013 | Paradigm Exercise & Fitness
Trimline manual
follow this steps and fix i.t God bless you
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • Sponsored Links
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2gXuRx33v
    Oct 02, 2013 | Exercise & Fitness
    My york treadmill t13i keeps displaying err 2 code
    see the details and fix it. God bless you
    This is probably a faulty speed sensor see the diagram attached, clean it and tight the connector . 2)test the input voltage motor, if there are voltage the motor need repair. 3)test the output voltage board for input voltage motor, if there are NOT a faulty control board or lower board. The error codes will differ between makes and models but could be e1.
    see the diagrams
    Nov 15, 2012 | Exercise & Fitness
    I have a treadmill york barbell max series 2, keeps displaying err in the speed window and wont start up at all, sometimes it will start working and then sometimes it wont and err comes up again
    1) You have out of adjustment the sensor reed switch,see the schematic.by 1/8" or 3mms aprox.
    2) With this you will fix it.
    3) However if the problem persist, you must check if the display board is o.k or faulty.
    4) Test the 5VDC for IC( Including EPROM, ROM,etc) Tight flexible cable for Display Board vs Lower Board(Main Controller Board).
    5) Since the Lower Board send the Power Supply coming from the Transforme you must Test it, and then power supply for +5Vdc.
    6) You must have Strong Conclusion if the problem is Upper Board or Lower Board(Main Controller Board) .
    Finally The Lower Board Control 90% functions of the Treadmills.
    Nov 23, 2011 | York Barbell Home Use Fold-Up Treadmill
    Stops 5-10 min into exercise; trips breaker,
    Dear Sir:
    Thank you by your request. I hope everything is o.k
    Now I will try to help you.
    You have electrical-mechanical Problem:
    If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
    Here are the most common symptoms and solutions:
    Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
    amount of time required to shut down will progressively get shorter.
    Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
    DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
    shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
    go for a cheap fix try lubricating the walking belt. The best fix is to replace the
    walking belt and then regularly maintain it and keep the treadmill clean.
    Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
    down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
    before it shuts down gets progressively shorter.
    Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
    electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
    the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
    belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
    Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
    shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
    reset it to restart the treadmill.
    Solution: If you get an error code, contact us with the code and make and model and we will try to help
    you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
    board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
    your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
    case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or
    some call it a console.
    Thank you in advance, sincerely. God bless you.
    If you need additional Help , please contact me.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    Sep 28, 2011 | Bowflex Treadclimber
    Err 1 displays after working for approx 1 minute
    Aug 14, 2009 | Horizon AFG 3.0 AT Treadmill
    Message in the display "err 2" and my kettler treadmill doesn't work
    Hi Rendra,
    Try this:
    Switch the treadmill off and then on again.
    Push the "minus" speed button and the "stop" button simultanuously.
    If all is well you will now have entered the maintenance mode.
    Next push the "plus" speed button and the "stop"button smultanuously.
    Now you you've reached the error mode.
    Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
    The push start to erase the message.
    Turn the power off and then on again to restart the treadmill.
    With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
    Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
    May 10, 2009 | Exercise & Fitness
    Precor C954i Commercial Treadmill Logo
    424 people viewed this question
    Top Precor Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Shehu Pro
    Shehu Pro
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
