Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher--water in bottom -end of cycle.
Happened with old dishwasher & new. Hose not clogged.
Water standing in bottom after cycle finished.We are stumped we did nothing yet.
  • Anonymous Feb 22, 2008
    water left in bottom after end of cycle
    President:
  • Whirlpool Master
  • 2,651 Answers
Although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Posted on Feb 26, 2008
I have a Bosch SHE4AM15UC dishwasher. It's been working fine, but yesterday I noticed that there was water in the bottom of the dishwasher after the cycle was finished.
Check the "P trap" where the drain hose connects under the sink. It may be partially blocked allowing water to syphon back into the machine or preventing it from pumping properly after the second or third pump out.
Nov 19, 2016 | Bosch Dishwashers
2in.of water standing in bottom when finished
Most likely a clog, either along the drain hose, or more likely, actually in the air gap vent. Disconnect the drain hose from the dishwasher and place a bucket under it. Run the drain cycle. This should clear any clog along the drain line. Remove the air gap vent from the top of the sink and disconnect the other hose. Remove the small cap at the top of the vent by pressing the small clips on opposite sides of each other and lift the cap out. Using either a strong flow of water, or, a thin, long-blade screwdriver, remove any debris from the two hose connectors. (Problem is most likely in the smaller hose connector which is preventing water from flowing over to the other connector to drain out). So, during operation, water goes up the small drain hose, but can't go any further and water remains in the dishwasher.
Clearing the air vent cap/filter should solve your problem.
Mar 20, 2010 | Bosch Evolution 500 SHE55M06UC 24 in...
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. once drained put it through another cycle. this should reset the drainage level. hope this works as it has for ours, bye
Jan 12, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 09, 2007 | Miele 24 in. G638 Plus Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,011 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
