Question about DeLonghi Dehumidifiers
My delonghi dec180e dehumidifier filter is jammed in the machine. it's also now leaking - how can I fix?
You can download the manual here: www.delonghi.co.uk/pdf_files/DEC180E.pdf
thanks
Paddy
Posted on Feb 12, 2010
How do I fix the water pump of a delonghi BC4264B? It's not pumping any water to make espresso. the machine heats up well, the steamer works fine, the drip brew side works fine. I'm not getting any...
Is there any water coming out of the group head when the porta filter is not used???the group head has a filter on it and it could be totally clogged
Jun 11, 2014 | DeLonghi DE500P Dehumidifier
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
My dehumidifier does not seem to be working properly. I can't find the manual to tell me what the settings should be. Would appreciate your help. It is a DeLonghi DE400P. Thanks Shirley
What is the specific problem? Is no water being collected by the dehumidifier or do you have another issue?
Make sure that the dehumidifier is in a room in the operating temperature range (at or above 44 degrees F). Make sure that the room door and windows are closed and that the room is not larger than 2200 square feet. Make sure that the collection bucket not full and is properly seated in the dehumidifier. Check and clean the air filter on the dehumidifier. (Vacuum the filter or rinse under running water three times. Then wait until dry to replace it in the dehumidifier.) Look at the coils of the dehumidifier. If you have ice on the coils, defrost the unit (turn off, unplug and wait for it to melt). If the ice reforms quickly, you may have a leak in the coolant system. Then the unit needs repair.
Next make sure that you have good air flow around the dehumidifier and that the desired humidity set point is lower than the humidity of the room.
Retrevo has the manual available: http://www.retrevo.com/support/Delonghi-DE400P-Heating-Cooling-and-Air-manual/id/19269bh037/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Aug 09, 2011 | DeLonghi Dehumidifiers
I have Delonghi DE500P dehumidifier was running but doesn't pump water. how can i fix it.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Aug 11, 2010 | DeLonghi DE500P Dehumidifier
Delonghi dehumidifier cf05m does not collect any water, why?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 18, 2009 | DeLonghi DH100P Dehumidifier
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Jul 14, 2009 | DeLonghi Dehumidifiers
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
Delonghi de400p dehumidifier does not work
if comp and fans running your out of freon or the compressor is not pumping more than likely out of freon and that means theres a leak in the sealed system high cost repair
Jul 03, 2009 | DeLonghi DE400P Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
Dehumidifiers Logo
222 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
