Brother mfc 240c i forgot to mention that i have already tryed cleaning the head through the printer functions more than 50 times and also tryed to reach behind black cartridge with q tip and alcohol. black cartridges still will not work???
    Brigadier General:
  • 3,917 Answers
Find a container or something and put the cartridge in it with the print head on the bottom. Then get a paper towel on standby. Pour boiling water into the jar lid and let the print head soak a couple of minutes then take it out and wipe it with the towel. If no ink shows up put the cartridge back in the water. You may have to change the water and put in more boiling water, but eventually it will work.
Make sure that the plastic protective tape on the new black cartridge is off. Calibration is one of the steps to perform right after loading. You can run "Self Test Diagnostic," as well as, "Print Cartridge Alignment" in order to get the black ink to work.
You can also try cleaning the black ink cartridge. Remove the blank ink cartridge from the printer; use a cotton swab to clean the laser or scanner block. Wipe away dirt, grime or any dried ink that may prevent ink from flowing. You can also try cleaning the printer heads.
If black ink does not print, go to "Disable the Cartridge" and switch the magenta and black cartridges on the menu. Then, print the pages again. If black ink does not print, then the problem may be the toner cartridge.
At times, when black ink does not print, it can signify a problem with a printer's laser assembly.
Another problem could be the wiring connection at the laser or scanner; check if the plugs are loose. Contact customer Support for further assistance.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 12, 2010
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Black not printing on brother mfc-290c! How do you clean the heads?
Press menu, thenpress 7, then press 2, it should say "cleaning." Select what color, press start, and your on your way!
May 12, 2010 | Brother Multi-Function Center MFC-240C...
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
BROTHER MFC-240C,UNABLE TO CHANGE 50
This error is usually caused by the Carriage Encoder Strip being dislodged from
the sensor mounted on the Print Head/Carriage Assembly.
Unfortunately, you will need to remove the scanner assembly, and top cover assembly to check to see if the encoder strip has come out of the printhead assembly.
May 05, 2009 | Brother Multi-Function Center MFC-240C...
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C
you might try a head cleaning and re calibration exercise first.
May 25, 2008 | Brother Multi-Function Center MFC-240C...
Magenta Color Doesn't Print
refill ink cart can be problem here, print head may be blocked , try cleaning the head in warm water
Feb 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
23 people viewed this question
k24674
