Question about Nintendo DS Lite
I broke the power switch on the motherboard of my DS lite when changing the shell. Can that piece be ordered?
    Guru:
  • 110 Answers
Yes, ebay do them very cheap, I just hope you have good soldering skills as you need a steady hand and a good eye to do it. (I know ive fitted enough of them).
If you have any problems with fitting a new switch message me and I will do my best to help you.
Regards,
SOD69
Posted on Feb 05, 2010
Brought a ds lite and new ds shell as the old one had broken hinge.Whilst re routing the black antenna cable broke (gold connection bit came off) i have ordered a new one from ebay.So as this is just for...
If you yourself have replace it, I think you damage the upper LCD ribbon connector. I have repaired a lot of DS, a broken hinge usually the cause of that problem( ribbon connector cut off ).
Check the upper LCD if that model have a seperate ribbon connector, luckily you could buy the ribbon only, if not, BAD LUCK, you have to buy a new upper LCD.
Hope that helps you out.
Thanks for asking FixYa!
Aug 08, 2011 | Nintendo DS Lite Console
DS lite Hindge Broke, how to fix
The only way to fix it would be to purchase a new shell and transfer the insides. You can find NDS Lite shells at the following page:
http://store.richspsxparts.com/newcoornidsl.html
Apr 20, 2010 | Nintendo Video Game Consoles & Games
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
Changed bottom screen tested before putting back
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Nov 19, 2009 | Nintendo DS Lite Console
Touch screen wont respond
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Jan 29, 2009 | Nintendo DS Lite Console
Ds lite
yes the new shell has this piece it's just not in the photo, it's in a bag not seen in most photos, you can replace this for about $25.00, or use a repair service on ebay
Aug 25, 2008 | Nintendo DS Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Ds lite
WHEN I PUT MY DS ON IT GOES OFF
Jun 14, 2008 | Nintendo DS Lite Console
Dropped and broke !
If your pretty good at dealing with small wires and parts there is a guide I found dealing with this problem
http://www.instructables.com/id/S405TMEFA0CVIFR/
Hope this helps and good luck repairing your son's DS Lite.
Jan 14, 2008 | Nintendo DS Lite Console
DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Nov 09, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Logo
70 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
