Question about Ricoh Aficio 450 Copier
Laser unit pl z . can you tell me how can i fixing a laser unit?
  • Eddy Key May 11, 2010
    what about it do you want to fix is it giving you a code or what.
    Scholar:
  • 78 Answers
Once a Laser unit has failed there is no was to fix it with out replacing the laser unit, the polygon mirror motor or associated parts (depending what has failed).
To access the laser take down the front cover (the one where you add toner) and remove it. The plastic cover around the toner/drum unit also needs to removed. Its the black unit behind, it will slide out after you have disconnected it.
Posted on Feb 20, 2008
I've super G3, print comes light and very very light 2 inches from left. pl help
Print the copy counter of the machine, check if the life of the drum unit is already reached. If the drum is ok, then you have to clean the laser unit. maybe dirt is blocking the light coming from the LD unit.
Apr 12, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Oiling the laser scanner motor
Remove top & side covers to reach laser scanner assm(see laser scanner assm,fig1) remove cover as specified in fig, remove 'C; clip to un lock ,take out scanner motor, lubricate shaft with good lubricate fix as it is..try..
For further assistance pl get back... pl take care while handling motor to aviod fingure printers on reflector..
Feb 05, 2012 | HP LaserJet 2200 Printer
Hp Laser Jet M1005 Scanner Error 12.. pls tell me ho i solve it.
Scan head(A part in flat bed scanner unit moving forward & reverse while scanning/copying) driving mechanism broken, replace it.For tech guys only:> open flat bed glass, pick out scan head unit,remove screws & detach drive mechanism,, Follow the snap shots to make alteration...Pl dont try it if you are not having that much technical skills..
12_16_2011_7_52_57_am.jpgThis information is giving you to on basis of my knowledge & experience, if you find any difficulty to alter the part just replace it with new one..Thanks for using FIXYA
Dec 16, 2011 | Office Equipment & Supplies
E220, e100
E-100 is regarding laser unit.pl check BD sensor,laser unit or IP board.
E-220 check scanning lamp or CCd pcb.
Aug 07, 2011 | Canon imageRUNNER 400S Copier
Error code OA
Error code "OA"....machine thinks it has a faulty Laser unit. You can try a reset ( Menu, *,M..press ENTER.) if it resets GREAT.
If not and the code comes back,most likely Laser unit is defective.
Expensive and time consuming repair.
Sep 05, 2008 | Muratec MFX-2500 Plain Paper Laser Fax
Error code
It is a heating roller warm up error. It should be looked at by a technician to fix the problem. It requires replacing parts to fix it such as the thermistor.
Jul 23, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Not working
cnu_jilla- with this unit it sounds like your laser unit may need cleaning , take a Q-tip and lightly wipe the laser eye . this may be all you need to do,top opening units tend to get dusty.Let me know if this helps. cooltek
Feb 29, 2008 | Coby TF-DVD7005 Portable DVD Player
MIXER PROBLEM
PLease advise what is the model of the mixer. If it is a Chef or a Major, it appears that the blades have not been fixed properly. Please push in till you hear a click
Dec 20, 2007 | Food Mixers
Ricoh Aficio 450 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
