Question about LG 32LH20 32 in. LCD HDTV
How do i make my freeview work on my lg 32lh2000?
How do i tune lg 26lc2r which is connected to cable for freeview
Freeview comes from an aerial; Freesat comes from a dish. If your TV does not have a satellite tuner, it will not tune channels from a dish.
Sep 17, 2014 | LG 26LC2R 26 in. HD-Ready LCD Television
My lg 32lh2000 switches on shows logo then turns of please help
That problem is on main board if you don't have sounds but if you have sounds the T-Con board is faulty not main board..
Feb 23, 2012 | LG 32LH2000 32 in. HDTV-Ready LCD TV
I want service manual for lcd lg 32 lh 200
Hello
There is no such model number you specifies here. 32LH2000 is there. I've the service manual of the said model. If you wants it, send me a mail and get it by return mail as an adobe acrobat document. gopakumarg43@ymail.com
OK.
Feb 04, 2011 | Televison & Video
What screws do i need to fit into back of my 32lg
I found a link to LG.Since I can't see where you are from and the site has the country all broke up,you can call the appropriate center.If you still have one of the screws that were removed,a local hardware store can easily match it up if you bring it in.Good luck!
http://www.lg.com/us/support/parts/support-find-parts.jsp
Jul 25, 2010 | LG 42PG20 42 in. Plasma HDTV
Need remotec remote control code to LG 32LH2000
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre/producthelp
also check the below link -
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
May 26, 2010 | Televison & Video
Need Sky Remote control code for LG 32LH2000 TV
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
http://www.skyuser.co.uk/tools/remotecodes/index.php
Please post comments if you need further help or information......
Good Luck!!
Mar 08, 2010 | LG 32LH20 32 in. LCD HDTV
We need freeview help
Just because your'e in a Freeview area doesnt necessarily mean you can recieve Freeview signals successfully without having to make other changes.
The most common other change you need to make is to install a different or higher performance aerial, or it needs to be re-located somewhere where it can get a better "view" of the transmitter, e.g. if it is currently mounted in the loft space then this may well give a good enough signal for the old analogue TV but wont be good enough for digital. It will need to be relocated outside, as high up as possible, and accurately pointed towards the transmitter.
Unfortunately without being able to examine your particular installation, it's impossible to say whether your current aerial is good enough for digital, but hopefully this gives you some ideas where to start, and if nothing else, help you discuss your problems if you engage the services of an aerial/TV engineer.
If your aerial is
Nov 07, 2009 | LG 42LC2D 42 in. LCD HDTV
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
LG 32LH20 32 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
