Question about Cornea Computers & Internet
The screen keeps turning on and off. It stays on but flashes constantly. Is there a manual fo this unit?
My screen is doing the same thing
Posted on Feb 02, 2010
Flashing indicators on my audi a3 dont flash but stay on constant
change it. most likely contains the flasher for turn signal also
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Jun 03, 2014 | Audi A3 Cars & Trucks
Turn off by itself
If your radio is aftermarket, it appears that your Battery Constant supply cable is loose, this cable is responsible for keeping the unit's last settings while the ignition is switched to off, check the fuse (if any) and if you cannot locate the issue, contact an auto electrician to arrange repairs, as loose wires can often cause vehicle fires or other damage. if you feel like fixing it yourself, refer to the manual for your head unit for wiring colors, most cases the Battery constant wire is yellow, and ignition power is red, this may vary, so check your manuals.
Oct 20, 2012 | Delphi XpressRC XM Satellite Radio...
Light flashes, clicking noise, fan does not turn
it sounds like the motor has a weak start winding or if the unit has a start capasitor it is bad
Feb 05, 2010 | Reiker Room Conditioner Ceiling Fan with...
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Unit keeps running constantly. I cleaned coils,
you should wait 5 minutes after turning off and back on again check thermostat may be bad
Oct 09, 2009 | Refrigerators
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
TV cycles on and off but never fully turns on
Tv POwers on shows a picture then picture goes and audio stays on
Apr 14, 2009 | Philips 43PP9202 43" Rear Projection...
Picture blinks on and off on my Trinitron Color TV, KV-35S36
My Trinitron Sony Television flashes off and on constantly and has horizontal lines.
Aug 31, 2008 | Televison & Video
Flashing light
this unit will have what is called ik protection wich means that the picture tubes are constantly monitor with this system all the way to the video procesor so the picture will desapear to a black screen even if the audio is ok,there may be a solution if contract a tech like me to adjust the bias so that compensates the drives to the pictures tubes since 1 or the 3 pt are week at this point.
Dec 25, 2007 | Sony KP61XBR200 TV
Computers & Internet Logo
93 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
