My xerox copier is broken - Office Equipment & Supplies
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Ok, thats nice. What is it and what is wrong???? My magic 8 ball is getting repaired
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Awww
  • 95 Answers
I'm sorry to hear that
Posted on Feb 03, 2010
Xerox Fuser will not warm up? Any idea why?
The fuser is nothing more than a heater element. One fuser is broken and the other isn't. You need a new one.
Or did you mean the broken one works in the other machine? In which case the power to it is disconnected somewhere.
Dec 27, 2015 | Xerox WorkCentre 4150 Black and White...
Have a Xerox 3210 workcentre serial no: 5294298012 but the top flap is broken looking for a replacement?
The hinges are available, the part number is 003N01051. http://www.iteminconline.com/itemdesc.asp?ic=003N01051&eq=&Tp=
Aug 28, 2014 | Xerox Office Equipment & Supplies
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Scaner belt broken need diagram
Yeah Xerox does no spare this part, you need the entire lower scanner assembly (109K01870). Item Inc offers them in exchange for pretty cheap compared to Xerox prices. Here's a video to show you how to replace it. Good luck!">
Nov 16, 2009 | Xerox C2424 Copier
Xerox m15i copier guide broken
This sounds like the paper path guide that sends the copy by the drum modual and then to the fuser.
If the walls are stained yellow, they the "vains" plastic guides are broken and will cause paper jams. Also after the paper has been fed out of the fuser modual there are other plastic guides that might appear to be yellow in stains. these tips often break and will cause constant jams.
The door guide has to be replaces and the vertical transport may need replacing as well. You would need to get part numbers for this specific model and someone who knows how to dissasemble this machine.
End result, you may need to call Xerox for assistance.
Good luck.
Oct 16, 2009 | Xerox WorkCentre M15i Laser Printer
The machine says my copier/scanner has failed to initalize . what do i do ??
This problem might need a Xerox Serivice Rep to repair the machine.
Sometimes the scanner motor fails, needs to be replaced.
The drive cable might be loose or have broken gears on the drive motor.
For indepth solutions, call Xerox, hopefully the labor and parts are included in the call charge. Xerox will warrenty the service for 30 days.
Oct 07, 2009 | Xerox CopyCenter C118PL Copier
Scaner not working
This will require a service call by Xerox.
This maybe broken or worn out gears and even a ciruit board to go out.
Check to see if the parts and labor are included with the call charge.
If it is take the service call and let Xerox repair the machine.
Oct 02, 2009 | Xerox DC440ST Copier
Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Apr 03, 2009 | Xerox DocuColor 12 Color Copier
Schematic of the Xerox XC865
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
k24674
jasbo
jasbo
