Question about Epson Stylus Photo R200 InkJet Printer
Hi My Epson Stylus R200 print is nearly unreadable. The status monitor says status is OK and the nozzle check is fine
    Sniper:
  • 54 Answers
Ensure the nozzle check has 6 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink.
Posted on Feb 02, 2010
After changing the ink, the red light is still on.
epson stylus photo R200 printer the two red lights are flashing can get it to work help
Jul 18, 2010 | Epson Stylus Photo R200 InkJet Printer
Epson stylus photo R200 status monitor in Windows 7
The epson R200 isn't supported in Windows 7. That's why the status monitor doesn't work.
Dec 28, 2009 | Epson Stylus Photo R200 InkJet Printer
Hi, my stylus photo rx520 scanner is not working correctly. printout looks like a tartan pattern. the scan operates but with this odd result. many thanks. Brian.
Check nozzle. Do head cleaning procedure from epson status monitor. wait for 15 minutes. Check nozzle again. Compare results from first and second nozzle check. Print out will perfect if the result of nozzle check as good as display pattern in nozzle check dialog box.
Aug 30, 2009 | Epson Stylus RX500 All-In-One InkJet...
Epson SX 205 ink insn't low but is not printing yellow or green
Status monitor just show approximately, not real level. It might be yellow and cyan ink is out actually.Others, yellow and cyan nozzle may be clog. Check nozzle, do head cleaning. Check nozzle again.
Jun 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
I have a epson stylus photo r200 do i need all colors to print just black and white?
HI-
Yes you need all the ink cartridges filled or they should have ink in it. That's one feature of epson printer to prevent air to clog nozzles.
Hope this helps
Sep 21, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Jul 05, 2008 | Epson Stylus Photo R220 InkJet Printer
R300 - quality terrible and no status monitor
If you're getting gaps in the nozzle checks and cleaning isn't resolving it, it is possible a nozzle is blocked with dried ink. You can get cleaning cartridges which contain a solvent that disolves the clogged ink.
I'll not suggest any brands, but talk to your local friendly computer shop, or do a search. Something like epson r300 cleaning cartridge should work.
When you say the status monitor is greyed out, is this on the computer or the printer? And I'd hope you're not using HP inks... It's an Epson printer ;) But on a serious note, I've not yet had any problems using non-Epson inks.
HTH,
Neil
Nov 27, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
133 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
