Rca tv with remote control.
Tv playes for a while then turnes off and want come on again for a while.
  • 44 Answers
While the set is playing tap or slap the side of the cabinet, to see if the picture flickers or goes off. (This is a deep dark secret technique of expert technicians :) )
If it does then you have an intermittent connection in the electronics, which will have to be repaired at a service shop.
Posted on Feb 19, 2008
Need code to program rca remote to my rca t.v.
rca technical support is sadly lacking... I used youtube to search for the remote model number to find a video that taught me how to search with the remote to get the proper code. ..try this, for tv hold tv button and power button on remote till power button turns red, next point remote at tv which is already on and press the play button on the remote. This causes the remote to try 10 codes. wait for the power button to quit winking at you, if the device (tv) turns off, it means that one of the 10 codes was correct. If the device stays on press play again to try the next set of 10 codes. It may take several tries. When it responds by turning off, we need to back up to the exact code by pressing the << reverse button one press at a time. When power comes on you have found the code. Now use the stop button to lock it in.:) I'll include a link to a vid. Programming an RCA Universal Remote If this helps please 'like' my answer.:P Mikee
Oct 13, 2014 | Televison & Video
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
How to code search RCA universal remote rcrno4gr to DVD player.
  • 1Turn on the component you want to program.
  • 2Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • 3Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • 4Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • 5Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • 6Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • 7Press and release the STOP button to save the new code
  • Read more: How to Program an RCA Universal Remote Control ' eHow.com http://www.ehow.com/how_9191_program-rca-universal.html#ixzz1dVicIcMK
    Nov 12, 2011 | RCA Televison & Video
    Rca remote not programming with tv
    I just got the same remote to work.  I did the auto scan method in the instructions.  turn on the tv, hold the tv and power button on the remote down until it stays lit.  Then press the play button, the remote will blink 10 times, press play again and the tv should turn off in a few blinks.  then when the remote finishes blinking, press the reverse button until the tv turns on again, when the tv turns on, press the stop button.  Hope this helps!
    Mar 23, 2009 | iLO 2600 Television
    Tip
    I hope that helps.
    on Apr 06, 2010 | RCA RCR311B Remote Control
    Can somebody tell me how to program a RCA 312w universal remote control to a emerson tv I have the intruction but I can not understand them thak you.
    This will work with any devise and the rca remote.
    1. turn on the device you want manually
    2.press and hold the devise key, while holding the devise key press and hold the on off key till it stays lit.
    3. point it at the devise and press PLAY for 5 sec. until it goes off. If it doesnt turn off after 5 secs. press and hold play again for 5 secs. repeat till unit turns off.
    4. After unit turns off press and hold Reverse for 2 secs. until unit turns back on.
    5. After it turns on hit STOP. and your done. Hope this helps.
    Feb 25, 2009 | RCA Universal Remote Control
    Rca remote with no code search button
    You didn't mention the model of the remote so try http://www.fixya.com/support/t839679-rca_remote_no_code_search_button
    and see if it is listed.
    If this works please repost,
    MM85
    Jul 27, 2008 | RCA Universal Remote Control
    RCA remote help
    I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON!!! MY REMOTE WAS THE RCA RCR312W
    1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
    2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
    3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
    4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
    5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
    6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
    8. To save the new code, press and release the STOP button.
    9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
    Jul 01, 2008 | RCA RCR311B Remote Control
    Rcr311b remote control
    I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON DON'T JUST PRESS IT ONCE LIKE A LOT OF SITES SAY TO DO.  I HAD TO PRESS IT A FEW TIMES, AND THEN IT TURNED THE TV BACK ON AND THE REMOTE WORKED!!! MY REMOTE WAS THE RCA RCR312W
    6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    Jun 27, 2008 | RCA RCR311B Remote Control
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
