Question about Nokia 5310 Cellular Phone
Security code!!! when i turn on my phone i get asked for my pin code i put that in and it works before i get to do anything with my phone after that a message box comes up telling me i have to enter my security code. i tried the default code which is 12345 but that didn't work what will i do???
  • 812 Answers
Hello i hope u 'll be fine.... thanks for using fixya.
if u r using your default code 12345 and its not working then your security code may be changed so solution is u should format your cell . All original settings will be restored and again default code 12345 will be active. so for format your cell u should follow following procedure
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone 'll format completely
Note :all your data will be delete in the process of formattingI hope this solution will work and helpful 4 u. Best of luck
If
it was helpful then Please do rate me. Keep using fixya. THANKS
Posted on Feb 02, 2010
Online chat
Go into ur phone settings, security settings, phone and sim. Scroll down to lock code.
To change the code to ur own, select it, and it will ask for the default lock code which is 12345. Once confirmed, it will ask u for ur new code which can be
4 or 5 digits. Pick something u wont forget. Then it will ask u to confirm it.
Done.
Now if ur phone has an autolock feature, u can set it by selecting it and selecting user defined and set a time, like 10 or 15 minutes, up to u. Ur phone will lock after
that set time of inactivity. U will still be able to take calls, but need to put the code in to do anything else. Code will be requested each time u turn ur phone on.
Depending on ur nokia, u may have remote lock feature. With this, u set a password, and if ur phone is stolen and ur worried that it hasnt autolocked, u can send that
password to ur phone from any other phone by sms and it locks it.
U may also have the feature to have the phone lock if the simcard is changed and u can enable that too.
Finally, u have pin lock. This locks ur sim card, even if a theif takes it out and puts it in another phone, the code will be required to use ur sim.
To change the pin code, its the same as the lock code change, but the default code u need to put in first is different. Its usually 00000 but if that doesnt work, select
cancel, and call ur service provider, they will give u their sim pin default code, and after uv done that, select pin request on, and it will ask for a code every time u
turn ur phone on.
Its a good idea to make ur pin and lock code the same so u just enter them consecutively on start up
Hope this helps. [answer taken from Yahoo.answers]
Jan 22, 2014 | Nokia Cell Phones
My phone is asking for a PUK code It will not let me get out of it or put anything else in, what should I do?
Dear Sir/Mam
Regarding your problem please contact your service provider. The PIN code supplied with the SIM card protects the card against unauthorised use. The PIN2 code supplied with some SIM cards is required to access certain services. If you enter PIN or PIN2 code incorrectly three times in succession, you are asked for the PUK or PUK2 code. If you do not have them, contact your service provider. The module PIN is required to access the information in the security module of your SIM card. The signing PIN may be required for the digital signature. The barring password is required when using the call barring service. To set= how your phone uses the access codes and security settings, select Menu> Settings> Security.
Thanks for using FixYa All the Best!
Aug 12, 2011 | LG TracFone 600 Cell Phone - TF600GP4
I typed in wrong code many times now it says phone freeze unavailable sim,and it just says if i want to call sos PLEASE HELP :(
there are diff types of codes in the phone..the security code and the pin code..try to remove the sim card from the phone first then put it back..turn on your phone, if your phone shows pin blocked, you have to call your service provider for the PUK (PIN unblocking code)..if you forgot your security code, it depends if your phone will still ask for the security code if you're going to remove the sim card. or if it will show you "INSERT SIM"
Jan 29, 2011 | Samsung SGH-Z240 Cellular Phone
Nokia N 70 - Error - 'Sim Card Rejected'
IF you put PUK code many times depending on the model it wil lock the sim card. This is because to prevent unathorised person using your SIM card.
Default PIN code for nokia mobile is 0000
PUK code will be given by the service provider only.
Please call your service provider or go to service provider office,they will assist you in this issue.And they will have a security check like name,Phone number and other information to check weather the SIM card belongs to you only.Then they will assit you.
Thanx
Jul 23, 2010 | Nokia N70 Cellular Phone
I have a Nokia 1661 tmobile phone that i just got. I turned it on and it asked me for the security code and i put it in and it says that it is blockedand then it asks me for the PUK Code bt i dont know it,...
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Oct 03, 2009 | Nokia 1661 Cell Phone
My LG KS360 web slider requires a PUK code!!
if you have a webslider just call 1300 555 002 and follow the prompts.You will talk to a real person and just ask for your PUK code they will tell you. :)
Jul 31, 2009 | Cell Phones
Nokia mobile phone PUK code
YOU WILL NEED TO CONTACT YOUR MOBILE SERVICE PROVIDER AND HAVE THEM GIVE YOU THE PUK CODE FOR YOUR PHONE.
Aug 21, 2008 | Nokia 6070 Cellular Phone
Sony E k550i
What kind of code is it asking for?
If it ask for a PIN code then it means it's asking for the password/code you have entered on your SIM card. If it asks for Security code then that means it's the password/code for the phone.
Entering three invalid PIN codes on your phone then your PIN may be locked and you can only unlcok it by entering the PUK code on your SIM. PUK code is available on the sim card pack. Once it's ented, you have the option of changing your PIN code. Just be sure to remember your PIN code so the same incident won't happen again. If it ask for security code, enter the code you have for the phone but if you don't remember setting a security code, then you may try the default security code of Sony Ericsson phones which is 00000.
May 05, 2008 | Sony Ericsson K550i Cellular Phone
Nokia 5310 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
