Question about HP LaserJet 2420 Printer
During printing the along the left side there is a black mark. Like the roller is drity.
  • 240 Answers
Depending on what the mark looks like depends on whether you can clean a component or have to replace the cartridge. If it is a small black dot at a consistent repetitive interval repeating 6-8 times/page then you may be able to clean it. If this is the case there is likely a piece of debris on the primary charge roller, it is a black rubber roller that should be visible trough the slot on the top of the cartridge. To clean the debris off you will need a dry clean Q-tip. You will have to rotate the imaging drum manually from the underside towards the end of the cartridge that goes into the printer first. Do this slowly and watch for a spot on the PCR where the defect on the page is. Hopefully you can find it and clean it off, if not you will have to replace the cartridge.
Posted on Feb 02, 2010
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
Spots along left side of page. On every printed page there are black spots along left side.
something on the fuser... is it the same distance from each spot every time?... then something is on the fuser roller, so it gets fused every time it rolls over that spot. thats my guess
Sep 08, 2009 | Samsung Office Equipment & Supplies
I have a HP Colourjet 2600n which has worked well for 12 months plus. However it has just started printing with thick black smudges along the left of every page. It looks like there is yellow powder...
If you have BLACK Marks on the paper the YELLOW roller does not need to be cleaned usually.
To clean the yellow toner off the roller use a DRY lint free cloth. For this issue my suggestion for a resolution to the Yellow toner issue is replace the toner. They are not supposed to leak in the first place.
As for the BLACK tone on the left of the page you most likely have a Fuser issue causing that.
Jul 27, 2009 | HP Color LaserJet 2600n Printer
Black marks along the edge of paper
there is probably ink on the rollers. get some paper and just keep feeding it till the black marks stop. and RECYCLE the paper that you fed. DO NOT throw it out
Apr 13, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Mar 16, 2009 | Brother HL-5240 Laser Printer
Ricoh Aficio AP3800C Printing Problem
If the marks are along the same line and look like dots the black photoconductor needs to be repalced.
Jan 21, 2009 | Ricoh Aficio AP3800C Laser Printer
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
1320n marks along left side of paper
repetitive defects are caused by either a ding on the drum in the toner, a scratch or dirty transfer roller, or scratched or dirty heat roller in the fuser, Last but not least is dirty exit roller. the first step to any print quality defect is to cahnge the toner cartridge. Good Luck!
Aug 04, 2008 | HP LaserJet 1320 Printer
Repetative mark along right side of printed page.
Roller is misaligned somewhere or gear is broken. It will repeat every several inches depending on the diameter of the roller and the section that broke. A small section break that repeats every three inches indicates gear malfunction on a roller whose circumference is approximately three inches.
Mar 06, 2008 | Dell 1600n All-In-One Laser Printer
White streaks in print outs
Check transfer roller, or change black cartidge, if it only happens to the black then there is something wrong with that part of the process.
Oct 22, 2007 | Ricoh Aficio CL2000N Laser Printer
HP LaserJet 2420 Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
