Question about Dell 0Y3740 Keyboard
How do i use the calculator on my keyboard ?
I have the num lock on, but I'm not getting anywhere.
  • 37 Answers
Check your function (fn) buttons as some laptops are set to use that rather than numlock
Posted on Feb 02, 2010
How do I switch from letters to number and calculator on my Dell keyboard Xp operating
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
May 07, 2012 | Dell SK8110 Keyboard
How do you turn off the calculator keys
This depends on the keyboard, but there should be a key marked "num lk" or similar for "number lock". Press this key in conjunction with one of the shift keys, probably the one marked "fn" if there is one.
Apr 21, 2012 | Office Equipment & Supplies
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
Cant get calculater numbers to turn of on my wireless keyboard
press num lock in the upper left corner of the numerical part (calculator) of your keyboard.
Feb 27, 2011 | Lenovo ThinkCentre A30 PC Desktop
0y n6teb662 2eyb6ard g5ves wr6ng 5nf6
You have your number lock on.  On your keyboard somewhere, there is a key labelled NUM LOCK.  Press it once and your problem should be solved.  There's quite often a warning light somewhere on your computer to tell you it's on.
The number lock is used to turn part of your keyboard into a numeric keypad, to use it more easily as a calculator if you're doing lots of adding up.
Please rate me if you found this useful.  Thanks.
Mar 07, 2010 | Gateway 7001433 Keyboard
I dont know how to use the number pad as a calculator
You need to open "calculator" in Windows programs accessories.
Jul 13, 2009 | Dell 0Y3740 Keyboard
How do i get the keyboard to type the letters instead of the numbers
hold the fn and shift and num lock keys down - this reverts to normal keyboard
Jun 22, 2009 | Acer NSK8458AN Keyboard
How to use calculator portion of DELL Keyboard
if you want to use the number pad, you have to make sure the the number light is lit, the number light is the lock symbol with 9 inside it. this symbol is found at the top portion of the keyboard. if its lit then you will be able to use the number pad.
Oct 07, 2008 | Dell 0Y3740 Keyboard
Calculator
check which function key at top looks like a number key pad or has written in gray, num lk. Mine is F11 press the FN + that key
Apr 18, 2008 | HP 510 Notebook
Dell 0Y3740 Keyboard Logo
641 people viewed this question
Alun Cox
