Question about Maytag Dryers
Maytag performa gas dryer appliance gets hot but have to cycle clothes 2 times to get dry, have vacuumed out lint trap and exit vent any ideas thanks.
  • 221 Answers
Hi, it sounds like you have covered most bases. One other thing I would check is total airflow. Outside, where the dryer exhaust leaves the building it should be unobstructed, If there is a flap or louvers they should open freely. You should be able to feel the warm air when you put your hand at the vent. If aiflow is good, the thermostat may be defective.
Posted on Feb 02, 2010
Takes about 4 hours to dry any load. Have tried different settings. Husband cleaned lint traps, hoses, etc. Gas turns on and shuts off about every couple of minutes. Any ideasa?
Most likely problem is the exhaust is plugged. Lint build up and eventually restricted the humid exhaust air.
To test for this locate the exhaust vent where it exits the house. With the dryer running feel for the air flow. It should be similar to the flow you feel from hair dryer.
Second test is to light load the dryer setting the heat to high and after several minutes of operation open the door and confirm the clothes are hot to the touch.
Hot clothes and no air flow for ever to dry!!
  1. Remove hose from wall connection. Confirm vent hose not plugged by running dryer. Very dusty process. If no air step 2.
  2. Remove vent hose from back of dryer. Confirm air flow from dryer. Very dusty process. No air step 3.
  3. Service dryer blower likely plugged with lint. If dryer basket turns I would assume blower is also turning connected by drive belt. The blockage internal to dryer.
  4. So if not 1,2 or 3 than blocked vent hose to the outside . Suggest using a vacuum hose to carefully try to retrieve lint build up. Lets hope that it is not a roof vent because it would really suck trying to pull the blockage out. And unless your Santa roof tops are dangerous places to play.
  5. Well at least at this point we know why the clothes are not getting dry. What ever you do do not breach the venting in the walls. Moisture will build up along with the lint and create havic with mold!!!
  6. Call your husband
26044146-iw0uppkrtuaby0cw3enjxd1j-2-5.jpg Not to sure about the leaf blower, Might work?
Dryer Vent Cleaning Quick Easy Trick
Jan 08, 2016 | Maytag Atlantis MDG7400AW Gas Dryer
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Dryer shuts off before the finish of the cycle. Clothes are not all the way dry.
If the dryer is on a timed-cycle dry, and the heat is too low and/or the air supply is restricted, the machine will shut off before everything is dry. If running on auto-sense dry, the exit air temperature sensor is shutting the machine off too soon or the air passing through the clothes is restricted somewhere and therefore getting too hot which shuts the machine off too soon. The primary suspect for air flow restriction is lint accumulation in the vents and/or the lint trap is plugged with fabric softener deposits--wash it in detergent and hot water. Hope this helps.
Aug 28, 2009 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
126 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
