Question about HP DesignJet 1050c InkJet Printer
Got the same problem. It makes a jerking sound when the carriage moves and pass the middle.
    Scholar:
  • HP Expert
  • 123 Answers
When the carriage is moving somewhere in the print area, pull the power cord and stop the carriage where you can reach it. Open the front cover and manually move the carriage through its range of motion. If there is an obstruction causing the noise, determine what that is and correct it.
If there are rubber crumbs under the carriage belt, the belt is disintegrating. This happens after 6 million cycles or 5 years with the OEM belts. New belts are available at http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Posted on Apr 15, 2010
I have an hp c 3180. Changed the black ink cartridge, the carriage went left where it is now lodged... I need to get the carriage out where I can check to see if the cartidge is properly seated.
Hi Richard,
Please follow the steps below to make sure that the carriage can move freely and is properly seated. Check the carriage path. Press the Power button to turn the product on, if it is not already on. Open the cartridge access door. The carriage might try to move into the access area at the right. Allow the carriage to move to that position.
1. Open the cartridge door.
2. Wait until the carriage is idle and silent.
3. Without turning off the product, disconnect the power cord from the rear of the product.
WARNING: In the following steps, you move parts by hand. You must disconnect the power cord from the rear of the product to eliminate the risk of an electrical shock and to reset the paper-feed mechanism.
4. Disconnect the power cord from the wall outlet or power strip.
5. Look inside the product to see where the carriage is stuck, and then check for any torn paper or other objects that might restrict the carriage.
NOTE: You might need a flashlight to illuminate areas for proper viewing.
6. Remove any loose paper or obstructions found.
7. Reach inside the product through the cartridge door, and then manually move the carriage.
8. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
9. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
10. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
11. Make sure the carriage moves freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.
12. Close the cartridge access door. Close the cartridge access door
13. Reconnect the power cord to the rear of the product.
14. Plug the power cord into the wall outlet or power strip.
15. Press the Power button to turn on the product.
Hope it helps.
Thank you for using FixYa.
Dec 26, 2011 | Office Equipment & Supplies
My Canon Ip2772 not printing. because i have error 5200 occurred. please send this solution. i m very glad to your solution
Please try this solution
Switch on the printer, while its moving the cartridge carriage unit, plug out the power cable.
Open the printer's cover.
Now the printer is off, and the cartridge carriage unit is located somewhere in the middle or any side.
Pull it to the middle of the printer.
Take out both cartridge from the carriage unit, and leave the "Lid" open wide.
Turn on the printer with the Lid still open. The carriage unit will now move to the left and to the right, and then stop again at the middle.
You can put back the cartridges according to the color code: C for Color, B for Black.
Close the cover, and try to print a page.
Oct 08, 2011 | Office Equipment & Supplies
My ptinter has a serious problem , every time i turn on it the print head jerks so fast right side and backs again then it doesnt work again , it sound it gets crazy , can you help me please , and how...
Might be your printer inkjet technology one, just observe back side of carriage assm a film called encoder strip which is helping to carriage assm for positioning, might be mis positioned, become dirty(there is en number of stripes on encoder) or encoder reader sensor got dirty/not working results carriage moves left to right faster. check above said components..if found encoder faulty replace it..best of luck
Sep 10, 2011 | Office Equipment & Supplies
Printer carriage stall/stuck
  1. follow the steps below
  2. Reconnect the power cord to the back of the product.
  3. Press the Power button ( ) to turn on the product.
  4. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position
  • With the product turned on, disconnect the power cord from the back of the product.
  • Unplug the power cord from the power source or electrical outlet.
  • Check for any paper or objects that might be stopping the carriage. CAUTION: If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams can occur.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove any loose paper or obstructions found.
  • Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  • Close the carriage access door.
  • Reconnect the power cord to the product and to the power source.
  • Reconnect the USB cable to the product.
  • Load plain paper in the tray.
  • Dec 19, 2009 | HP Office Equipment & Supplies
    How to remove the cartridge from hp photo smart 7960
    Hello the manual way to release cartridge is
    1. Disconnect the power cord from the printer.
    2. Open the top cover.
    3. Look for the gray-colored carriage on the right side of the printer.
    4. Find the horizontal (bottom) edge of the carriage and follow it towards the back (or in) until it makes a 90-degree turn. Follow it down to the ¼ inch-high, black-colored capping station.
    5. Using a screwdriver or similar tool, push the capping station toward the back of the printer.
      NOTE: Do not pull on the ribbon cable when moving the carriage.
    6. Making sure to not push up on the carriage, move the carriage to the middle of the printer. If the carriage is still locked in place, push the capping station farther into the printer and try moving the carriage again.
    7. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges and store them according to specifications.
    8. Close the top cover.
    Sep 03, 2009 | HP PhotoSmart 7960 InkJet Printer
    Olivetti Lettera 32 Carraige Jammed to the left.
    carriage return release lever is on the right --low right side, with a spoon shaped end, it engages a notch on the underside of the return and locks it in place--push it forward to release the carriage return
    May 29, 2008 | Office Equipment & Supplies
    Carriage Jam
    first of all,just look for any obstruction or any peice of paper,specially where the carriage rest ,check the carriage belt is it look physically ok,check a transparent stripe which is behind the carriage unit it passes through the circuit behind the carriage,check all n revert accordingly
    thnx N
    Jan 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    Ink carriage does not move...
    the carriage is hooked when it tried to move that why the noise you try to set the carriage so as to balance and free it self then it will move ive had similary and i resolved it that way
    Jan 21, 2008 | HP OfficeJet 7110 All-In-One Thermal...
    Turn power off. check printhead path (2)
    looks like the oil they used on the rails must have left a coating on the rail. because i cleaned them with a solvent and used HP oil problem appears to have gone away
    if it doesn't go away try replacing the motor.
    Jan 07, 2008 | HP DesignJet 1050c InkJet Printer
    Clear carriage jam
    Follow the instruction suggested by Hp at the link below. If it makes you feel any better I have done this myself and it works.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00300520&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en
    Dec 20, 2007 | HP PSC 1610 All-In-One InkJet Printer
    HP DesignJet 1050c InkJet Printer Logo
    467 people viewed this question
    Ben Johnson
