Question about Nintendo Wii Console
Wont connect to the internet - Nintendo Wii Console
  • 864 Answers
I can help you with this. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
My daughters lexibook tablet 2 wont connect to internet?
try to look on youtube on this should be easy to set up , just goto setting and internet options etc ,
Feb 26, 2015 | Lexibook TABLET MASTER 2 7IN 8GB 1GHZ...
When i connected my belkin n150 it wont connect to the internet the modem light flashes amber ,It says connected on my laptop but the modem light wont stay green
Your Router Should Be Configured for your Internet Service Provider. To do that you have to contact your Belkin technical support & they will give you a hand. Or Please update some Details about your Internet connection who is your Internet Service Provider. What type of Internet Connection are you using is it DSL or Cable. And i will walk through the Steps For you... :)
Mar 07, 2011 | Belkin (F5D7230-4) Router (587009)
My laptop wont connect to the internet...it connects to the router but then wont connect to the internet and its not the router or modem wont connect to a wired connection either
I would hook your laptop up directly to your broadband modem and bypass your router to rule it out. Plug the network cable from your modem into your laptop. Unplug the power on your broadband modem and plug it back in. Restart your laptop and see if you get on-line.
If you can...your router is the issue. If you cannot....I would check with your internet service provider before troubleshooting further.
Jun 04, 2010 | Gateway CX2726 Tablet PC
Asus eee pc 4g wont connect to internet with
Can you connect through a "wired" connection? Is your router connected to the Internet? If you're using wireless encryption, have you told your netbook what that encryption key is?
Apr 29, 2010 | ASUS Eee 4G Notebook
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Onix wont accept music download
dear first check ur internet settings in ur onix. if not plz configure it. but the fact is for access internet u need internet service provider. i think u can use internet from ur pc connected ur onix with pc. when ur pc is connected net then ur onix is also with connected net. then u can access from it. thanks
Jul 27, 2009 | Audio Players & Recorders
Ps3 wont go on the internet
Check and make sure its set to automatically obtain dhcp settings.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
It wont work
sorry..can you pls elaborate on this...
i suppose IE 7 is installed & is not able to connect to the Internet.
If that's the case then chk your internet connections, Proxy setting if any....
warm regards
Mar 16, 2009 | Microsoft Internet Explorer 7
Internet connection
Always tell us the make and model of your system and the operating system you are running.
In your case, you should also mention how you connect (when you do).
Aug 19, 2008 | Computers & Internet
The other computer wont log on to the internet
hi, even if it's connected properly if its not properly configured it still wont connect..so does it mean that other pc could connect? how bout your main pc does it work? which pc wont work? whats the o.s.? if you like i could help you i just need to know the full detail so i could help you diagnose it
Nov 28, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Nintendo Wii Console Logo
15 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
