Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 gas oven we replaced the ignitor and the oven does not work the broiler does
  • 221 Answers
Hi, this could still be a defective igniter, to verify you need a volt meter. The voltage being delivered to the oven gas valve must be at least 3.1 volts ac. Anything less and the valve operation is unreliable. If you have 3.1 to 3.3 volts to the valve when the thermostat is calling for heat and no gas, the valve needs to be replaced, If the voltage is lower, change the igniter.
Posted on Feb 02, 2010
4 Suggested Answers
SOURCE: GE gas oven won't heat
Replaced glow plug its getting current but still not glowing. Tested resistance 1100 showed good,
but glow plug still no lighting
Posted on Dec 13, 2008
SOURCE: how to change an ignitor on a XL44
I have the same problem,,, did you find a way? The screws are not readily accessible, there must be a trick.
Posted on Feb 07, 2010
SOURCE: Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Posted on Feb 04, 2011
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My GE Sprctra XL44 oven does not work, but the broiler and stove top still work. I guess it's the ignitor. I don't have instructions anymore.
    heatman101
    Jan 06, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Xl44 stove, the burners and broiler work but the oven won't turn on.
    heatman101
    Dec 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have a ge xL44 and I can't get the oven or broiler on...How do I get the pilot to light?
    heatman101
    Dec 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 oven not working, but the broiler is...???
    CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
    Jan 28, 2009 | GE JGRP17 Gas Single Oven
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    743 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Sal De
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
